Plastic Bronco Body Panels
nwoffroader
Justin
Roseburg, OR
22 Bronco 2D, 72 Bronco, 78 Bronco, 90 Bronco
I was pulling of the small rear plastic body panel under the passenger side taillight off and the plastic piece on the inside that holds the two white push clips came off of the body panel. I'm trying to figure out what type of plastic these pieces are and what type of glue to use to bond them back together. I've searched and found nothing helpful so far.
mj63
Matt
Toledo
The plastic type is probably molded into the back side of the plastic (for recycling purposes) - this goes for most plastic used in the automotive industry.
nwoffroader
nwoffroader
Justin
Roseburg, OR
I didn't see any of the symbols, but I'll look again, thanks.
GaMeg
Meg
Rock Spring, GA
2023 Ford Bronco
The same thing happened when changing my tail lights. My husband used some strong double-sided tape to hold it together. It was the long skinny piece to the inside of the tail light that came apart on mine.
nwoffroader
nwoffroader
Justin
Roseburg, OR
Thanks for the response, I appreciate it!!!
