Full disclosure, I've ben known to occasionally run with scissors and drink from a garden hose, so my idea of safe may be a bit sketchy.Yes, I lift my Bronco from the frame on all four contact points (front and rear, left and right).
The QuickJack system, when set up and used properly, is very stable. You need to carefully line up the QuickJack Frames, SUV and Light Truck Adapters, and the Lift Blocks with relatively flat spots on the frame before starting the lift. If the truck adapters and/or lift blocks tilt a bit after contact with the frame, stop lifting, back off an inch or two, and line them up again. You also must remember to lower the Lock Bars onto the fixed Lock Blocks and depressurize the hydraulic system before working on or under the vehicle. Never rely solely on the hydraulic system in between the fixed Lock Blocks, because any hydraulic system can fail and depressurize, causing damage or injury.
@kodiakisland and I both worked underneath my vehicle for an entire day over a month ago, using the QuickJack to replace all of the factory skids with aftermarket skids, and we both felt the system was very safe.
