Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
I recently purchased a portable QuickJack Model 7000TL to work on my Bronco.
I bought it during a special sale on 2/22/22 for 22% off -- thanks to @GToddC5 for the valuable heads-up! -- but was waiting for warmer weather to install it.
Installation day was today! 🛠
Below are a few photos, in case you’re curious about what it looks like.
1) All of the parts from the 3 main boxes unpacked…
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D EA6C332D-26F1-43EC-9DCC-D35135F47182
2) Location I plan to use it in the garage…
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D 235B57AF-5768-4912-8C7B-CCA180463500
3) Badlands Sasquatch 4D at full lift, using Truck/SUV adapters plus one rubber block on all 4 lift points (medium blocks in front, and tall blocks in back, to level the factory rake)…
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D 0573FD6D-C37D-4663-A9C0-176261645272
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D CDC460EB-8EAE-4FC1-825A-6A9778AA30FD
4) Full droop on the front and rear of the Sasquatch suspension…
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D DD965B28-B0B1-4D86-B670-66A9D76682A3
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D EB60D3E0-0390-4A7C-BD8C-80035B987CA4
5) Clearance below rear Sasquatch wheels/tires at full droop (~6”, just eyeballing)…
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D FF44EC7C-ED0D-49C4-8F84-B78040F48A98
6) Eye level for me (6’4” tall) — at center-line of the photos below at full lift — of the hood, rear half with top down, and spare tire…
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D FA1195D6-7B82-4169-BF2F-BDA0AD458F3D
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D 9E569FB1-5BD9-47A0-BCA0-31DC8B2B7271
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D BFB98D58-9097-4BFE-BB36-053E0315DC49
First Impressions
5-Star rating! This portable lift system is awesome!!! To be honest, it’s everything I hoped for. Very easy to operate, fits the Bronco frame rails well, and provides plenty of room to work underneath. 👍
Note: It’s technically not recommended to add any rubber blocks above the Truck/SUV adapters, but I wanted to see if it could be done and still maintain stability in the upper safety lock position… that’s now been confirmed! However, from a practical standpoint, it’s actually a little too high to work underneath comfortably, because I can’t reach parts and fasteners underneath without extending my arms constantly, which is pretty fatiguing for more than just a few minutes at a time. Therefore, I’ll forego adding the rubber blocks when working underneath and just stick with the Truck/SUV adapters.
I hope some of you guys and gals find this information helpful. 🤙
:EDIT: — A link to the current QuickJack Set-up and Operation Manual can be found on the Downloads page in the Support section of the website. I cannot post it here as an attachment, because the file size is too large.
5280Bronco
Denver
6) Eye level at center-line of the photos below at full lift (for me, 6’4” tall) of the hood, cargo bay with top down, and spare tire…
First Impressions
Looks like an awesome option. I've debated looking into one of those for my other cars as well, now I know it would work for all of them.
Strykerwsu
Wichita
Holden Commodores
Have had mine for 3 years. Works on Ram, Chevy SS, Flex, and Bronco. Figure, I about have my payback complete with all the work I do on them,
KPLOBX
Kristopher
Savannah GA
Jeep Wrangler TJ
This looks awesome. Thanks for putting this up
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Nice! I’ve had them bookmarked for months. Wish I caught onto that sale. Question - how far forward does it lurch the vehicle? Clearance was a concern for my tiny garage. I was thinking I’d more often than not - just roll them into the driveway and do the work there. But, then that limits me to work on the vehicle only when it’s nice out when I’d rather be on the trail or fishing. Haha.
One day my garage will get a reno and this won’t be a concern.
Razorbak86
Razorbak86
Northwest Arkansas
In the Set-up and Operation Manual, this is referred to as Radial Shift, and it can be anywhere from 11 to 15 inches.
Ford Bronco Portable QuickJack 7000TL to Lift a Badlands Sasquatch 4D C282C1B0-9FB3-4B13-80D2-7CEB042E9F6E
GToddC5
Todd
South Jersey
www.bronco6g.com
Very nice, glad you like it so far!
Razorbak86
Razorbak86
Northwest Arkansas
Dude, you saved me $400! Thanks again! The next time we get together, hopefully we can go wheeling! 😎
GToddC5
Todd
South Jersey
www.bronco6g.com
Looking forward to it! Planning my first oil change soon (saw your tip for the Quaker State, thanks!) and it will be time to start exploring after break in.
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
I have a 6000ELX that I use on my Model 3. Just ordered the truck extension and will try this out. I imagine you lifted from the frame running down the sides of the Bronco correct? How stable was it? The 6000ELX is quite a bit longer but looks like it will fit in between the wheels.
Razorbak86
Razorbak86
Northwest Arkansas
Yes, I lift my Bronco from the frame on all four contact points (front and rear, left and right).
The QuickJack system, when set up and used properly, is very stable. You need to carefully line up the QuickJack Frames, SUV and Light Truck Adapters, and the Lift Blocks with relatively flat spots on the frame before starting the lift. If the truck adapters and/or lift blocks tilt a bit after contact with the frame, stop lifting, back off an inch or two, and line them up again. You also must remember to lower the Lock Bars onto the fixed Lock Blocks and depressurize the hydraulic system before working on or under the vehicle. Never rely solely on the hydraulic system in between the fixed Lock Blocks, because any hydraulic system can fail and depressurize, causing damage or injury.
@kodiakisland and I both worked underneath my vehicle for an entire day over a month ago, using the QuickJack to replace all of the factory skids with aftermarket skids, and we both felt the system was very safe.
