Possible Modified Sasquatch?
Broncsquatch
SoCal
66 Mustang
Am I reading too much into this or is it because it's exactly what I want in my 4-door?...ok with 35s
But isn't this the Sasquatch with a manual trans with 33s?
4-Door specs:
Badlands, manual transmission, optional 33" Goodyear MT tires, Ford Performance beadlock wheels & rings. The manual transmission on the Badlands has a 4.70 gear ratio.
2-Door specs:
Badlands, auto transmission, 33" BFG AT tires, standard wheels, Ford Performance steel modular front bumper. The manual transmission on the Badlands has a 4.46 gear ratio.
Broncsquatch
Broncsquatch
SoCal
66 Mustang
Doesn't the 4.7 gear ratio only come with the Squatch package that is currently available only in AT?
So, isn't this the Badlands with a Sasquatch in MT and 33's?
BroncoFanBoy
Brandon
Az
Nissan
4-Door specs:
2-Door specs:
Maybe I’m tired, but this made no sense to me.
Broncsquatch
Broncsquatch
SoCal
66 Mustang
Sorry if I was unclear...
I'm referring to the description of the vehicles used on the Rubicon Trail vids
DrewBronc21
New York
badlands manual comes with 4.7 gear without Squatch
Ford Bronco Possible Modified Sasquatch? C855C5DF-F436-41F8-95B1-F6EF9F9A79F0
Jhuff
J
Toyota Tacoma and DR650
Additionally, one of the answers on the Ford Tweet stated that different gearing would be an option at ordering. So I am guessing that even if you go the auto route, you would still be able to get the lower gears with the automatic even without Sasquatch.
Spooled
Republic of Texas
I wouldn't take that to heart that it's going to be available across the entire trim line. As of right now the only trims listed with having multiple axle ratio options outside of the sasquatch package is the OBX and Big Bend w/ the AT.
Ford bragged about the super low crawl ratio in the reveal and then we found out that only applies to a standard MT Badlands.
Jhuff
J
Oh I don't take any of the statements to heart, being as the "Compare Models" sheet still contradicts Levine as to what transmissions are available with the Sasquatch. I looked through the specs for the OBX and BB, and didn't see anything about gearing. Where are you guys finding these more detailed spec sheets?
Spooled
Republic of Texas
Post #6 in this thread... scroll up.
https://www.ford.com/suvs/bronco/2021/media-kit/
Scroll to the bottom for Downloadable Spec & Fact Sheets
Jhuff
J
There is no need for me to scroll up because I was asking for the source of your information, rather than a screenshot of potentially out-of-date information. But thank you for the link, I had not found those sources myself yet.
As for the available gear ratios, there is a lot to go through, but I have not stumbled on anything yet that limits the optional gears (mentioned in the tweet) to trim levels. Again, i take that with a grain of salt since there are many discrepancies from these different sources.
