Black Diamond?NOT a Base
I just emailed dealers to add the Sasquatch. Lol. I hope it isn’t too late.I'm going to write the dissenting opinion here--the Base-Squatch is still better than this method--because I think this is what you were asking to hear.
Yes. Maybe it only takes a 1" body lift or you might have to add coil spacers, but I think Daystar will have something out for less than $500. You might need to remove those crash bars and since you're buying tires pick up some steelies with a better offset.
Here's the bit about going off-road with that setup:
Stay off the skinny pedal!
The big tires are much heavier and the Bronco has more Hp and Tq than people are giving it credit for which could easily snap an axle under the right (wrong?) circumstances.
If you're getting an automatic anyway, then the Sasquatch package is a no-brainer like others said.
Non-Sasquatch BL-
So would 33’s look and do better?Not only a lift, but you’ll need at least a +30mm offset wheel for the tires to clear the upper control arms.
I’m going to triple the sentiment: By the time you get it done on your own, you’re at or above the price of Squatch.
Op, some back of the napkin will tell you:
Wheels (5)
Tires (5)
Coil overs (all 4 corners)
That’s bare minimum
Then there’s the regearing, and the wider fender flares (which are already in the accessory catalog and are more expensive then you’d guess).
That’s all to just get you squared away with 35s on your base.
If you had clicked the Sas box you’d get all that *plus* lockers front and rear.
The only caveat is if you want a manual transmission as well... but if so, just wait for MY22.
It’ll still rub on the inside....Sure just take the whole fenders and quarters off.
And use a hammer!It’ll still rub on the inside....
