Yes I did. I went with the heavy-duty modular.Nice! Did you upgrade the front bumper?
Thanks for crapping on our daySo there goes the theory of these going out to confirmed owners. Imagine being the guy who gets a factory picture of a Bronco they never own due to dealer ADM at purchase.
Ok, more needs to be said about this, I have been trying to run this cable for the last 45 min. With alot of fuckery to be had. Are you removing lower panels to fish this out?I am starting easy mods, added a power port for my Garman. The Aux switches make wiring simple. Next is a light bar
I took the end of the wires and taped them together, to the end of piece of coat hanger. I worked it from the top down through the hole. From the glove compartment opening I could see behind the front console. I moved the wire so I could locate it. Once I found the wire I used mechanical fingers to pull the wire all the way through. I took me about two hours.Ok, more needs to be said about this, I have been trying to run this cable for the last 45 min. With alot of fuckery to be had. Are you removing lower panels to fish this out?
Not a easy task, I was left wondering if there were air conditioning ducts in multiple layers. Also the difference between models. I still had no luck. Tapped out and sinched things up. May try again tomorrow.I took the end of the wires and taped them together, to the end of piece of coat hanger. I worked it from the top down through the hole. From the glove compartment opening I could see behind the front console. I moved the wire so I could locate it. Once I found the wire I used mechanical fingers to pull the wire all the way through. I took me about two hours.
It was just easier to order the Lux package. Although I never got a picture of my Bronco leaving the assembly line, at least my Bronco showed up with Lux and Tow as ordered.I made my own hole, forward of the accessory mounting base. Be very careful when poking around the back of the console as there is a lot of wires. What hole are you trying to route the wires through?
II made my own hole, forward of the accessory mounting base. Be very careful when poking around the back of the console as there is a lot of wires. What hole are you trying to route the wires through?
