Pre-Run Wiring Locations
Dreadnought
A8L, cube, Corvair
Does anyone know for certain where the ends of the aux switch pre-run wiring are located?
Need fog lights on my Badlands.
PWillette
Parrie
Maine
Seems though there was a previous thread or video showing a junction box mounted in the engine bay.
Thed
Ben
Raleigh, NC
The relay box for the Aux switches is next to the standard fuse box by the battery. The wires will be wrapped up in the harness right next to it.
Hey19
JJ
Bethlehem
I'd like to see that location as well, it makes sense it would be in the battery/fuse/relay box area.
Tricky Nick
Nick
St Charles, IL
2009 2dr JK, manual, AEV lifted, 35’s
Dreadnought
Dreadnought
A8L, cube, Corvair
Very helpful responses- thank you.
Thed
Ben
Raleigh, NC
Here's the relay box
Ford Bronco Pre-Run Wiring Locations 1614206640950
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Do we know if there are any plugs in the firewall to run wires into the interior? Seems to be harder and harder to route wiring as cars get more complex and access is tighter. I will likely want to run power to an amplifier and reverse/work lights.
Thed
Ben
Raleigh, NC
Ford Bronco Pre-Run Wiring Locations 1614208567310
