Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now.
Josh/AWE
Josh
Horsham, PA
AWEBronco, AWEJT, F80 M3
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. awe_email_header_product-release-forum-png-png-
One exhaust. Every terrain. Presenting the 0FG Catback Exhaust Suite for the 6th Gen Bronco:
  • Modular design enables 0FG to be the one exhaust for every terrain
  • 2.3T, 2.7TT, 2-door and 4-door applications – all covered via one exhaust
  • 3” modular catback configuration
  • Bespoke mounting bracket allows for 2.3T installation without bumper removal
  • AWE BashGuard™ included in every configuration to provide best-in-class clearance on the fly
  • BashGuard™ features a .125” thick reinforced stainless ring on the outlet, built for bashing
  • Tip options include dual 4.5” slash-cut or single 5” straight-cut, all double-walled, and available in chrome silver or diamond black
  • Features locking collars for exhaust hangers to prevent movement
  • Handcrafted from CNC mandrel-bent, U.S.-sourced .065”-wall T304L stainless steel
  • 2.7TT dyno verified gains of 4 hp and 3 ft-lbs of torque at the wheels
  • 2.3T dyno-verified gains of 3 hp and 3 ft-lbs of torque at the wheels
  • Less is more: clean, straight-through design for maximum performance and tone
  • Proudly engineered, designed, and manufactured in-house, in the USA
  • Pure bolt-on, no-cutting required
  • Perfect Fitment Guarantee
  • AWE No CEL Guarantee
  • Lifetime warranty
The 0FG Exhaust
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_5
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-22789_5
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-32456_5
Handcrafted from US-made 3” T304L stainless steel, the 0FG Exhaust is straight-through catback configuration applicable to all Bronco models – 2.3T, 2.7TT, 2-door and 4-door – with modular capabilities unlike anything on the planet.
The 0FG Exhaust features a bespoke AWE resonator in the midpipe to produce an appropriate dose of aggression, followed by smooth bends towards the rear of the Bronco. On the way to the rear, depending on how many doors there are on your Bronco, lies an included adapter to bridge the difference in length across models. 2-door owner simply won’t need these adapters, but 4-door owners will be thrilled.
The 0FG modularity shines at the final break point in the exhaust route. Not only does the 0FG accommodate various tip options, it also accommodates AWE’s BashGuard™. What’s BashGuard? Thanks for asking. The AWE BashGuard™ is included in every 0FG exhaust, and enables the 0FG to be the one exhaust to rule them all.
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_2
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-22789_2
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-32456_2
Thanks to the modularity in the rear, simply remove the rear axle-back portion of the 0FG and replace it with the high-tuck BashGuard™. BashGuard™ is appropriately equipped with a .125” thick reinforced stainless ring. Perfect for bashin’.
Tip Options:
  • BashGuard (no tips): the configuration tailored for drivers who are too busy getting rugged on the trail for anything else. All of the precision engineering of the 0FG exhaust, but no tips. Instead, high-tuck reinforced stainless steel hiding above the tow hooks well out of harm's way. Get buck.
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_6
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_7
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_8
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_9
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_10
  • Single Side Exit: one big ‘n’ proud 5” double-walled, straight-cut tip exiting behind the left rear tire adds a dose of aggression to the Bronco you never knew it needed. Available is chrome silver or diamond black finishes.
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-22789_6
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-22789_7
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-22789_9
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-22789_10
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-23789_9_1
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-23789_10
  • Dual Split Rear Exit: dual 4.5” double-walled, slash-cut tips exiting below the rear bumper. This configuration adds needed symmetry to the Bronco’s very asymmetrical bumper, and it was engineered with aftermarket bumpers in mind. Available is chrome silver or diamond black finishes.
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-32456_6
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-32456_7
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-32456_9
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-32456_10
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-33456_9
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-33456_10
What’s in the box?
Complete 0FG Catback Exhaust including 4-door adapter and BashGuard™, tips and bracketry (if applicable), and all necessary hardware for installation.
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-21000_4
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-23789_4
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. 3015-33456_4
Data:
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. AWE_Bronco_23_Wheel_Dyno
Ford Bronco Presenting the AWE 0FG Catback Exhaust Suite for Bronco, available now. AWE_Bronco_27_Wheel_Dyno
JoeyGoats
Joey
Hatboro, PA
2016 3.5 Ecoboost F150
Does this mean I start blabbing about it!?!?! 🥳🥳🥳🤘🤘🤘
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
Is there a significant difference in sound without the tips installed?
Have had your exhausts on my S4 and M4 and loved them both.
Sara/AWE
Sara
Horsham, PA
www.awe-tuning.com
Glad to hear you liked them!
There are slight sound differences between the single and dual outlets. The BashGuard™ only option is going to sound similar to the single tip option. I will see if I can find any videos showcasing BashGuard™ only sound clips and post them below.
cigartexan
Jack
Boerne, Texas
1964 F100 SS - 2012 F-350 SD - 2021 4D Bronco FE
Ordered!
Sara/AWE
Sara
Horsham, PA
www.awe-tuning.com
Check out MainLineOverland's video for a more in depth look at the design process for the Bronco, a look at our facility here in Horsham PA, an install guide, and some sound clips at the end.
