Price jump from 2 to 4 door on Base Model
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
Anyone know why it is like a 5k jump on the Base as compared to the others?
Mike20
Upstate NY
2015 F150
One of the reasons appears to be transmission options. The base 2 door comes standard with a manual transmission and an option for an automatic transmission. The base 4 door comes standard with an automatic transmission.
(If this is incorrect, someone feel free to correct me)
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
Power
Standard
  • Post-Impact Braking
  • Electric Parking Brake
  • 2.3L EcoBoost® Engine
  • Electric Power-Assisted Steering (EPAS)
  • 7-Speed Manual Transmission (2-Door) Open image overlay for 7-Speed Manual Transmission (2-Door)
  • 10-Speed Automatic Transmission (4-Door)
Sighlense
Sighlense
Upstate NY
yes, subtract the difference in the Base 2 and 4 from the BB and BD and you'll find the cost of the automatic upgrade :)
So the Automatic tranny is about $2500 then? I couldn't figure out why the difference until Mike20 had me dive deeper.
uncledoodoo
Everglades
Everglades
so I get $2205 for the cost of the automatic upgrade, based on the 2-4door jump on the other levels.
Fuzion2Bronco
Asher
New England
Base Sasquatch
Desert_6G
Phoenix, AZ
Ranger
That's why I got to. Seems a little pricey for just a ATX upgrade. Now if it came with the 2.7 with auto then it would be worth it.
pan-y-cerveza
Manitoba
Tacoma Pro
Just checked Base 4 - Door comes standard with 2.3. Option is 2.7.
You're correct. I was surprised when I saw the 2.7L only as I hadn't seen it mentioned. Turns out I wasn't reading their spec list right. Everything is in a 2 or 4 door column until you get to the bottom of the page and then it's 2.3L and 2.7L column.
Also... While looking further under "highlights" it shows the 4 door base as having auto or manual. So... o_O
Ford Bronco Price jump from 2 to 4 door on Base Model Screenshot_20200806-161711_Chrome
Also while searching I noticed that the ford.com site doesn't work near as well as the ford.ca site for comparing models.
uncledoodoo
Everglades
Everglades
That's the only difference in the base that isn't in the next models between 2 and 4 door. Hopefully you're right and they just had some price model to bury (like a loss-leader on the 2-door maybe), and it will be less of a jump than that. I'm trying not to let the wife get her way on the automatic, but if she does I'll have to get the 2.7 too.
uncledoodoo
Everglades
Everglades
the "highlights" section covers all levels (notice it mentions black diamond and big bend too?). Its not the same details as the per-model details which show the auto as standard on 4-door. and its the only thing that "justifies" the $5K increase for the 4-door on the base.
Fuzion2Bronco
Asher
New England
Base Sasquatch
Highlights info shows what is available and Not Only Standard Equipment. But if you drilled down to the Specifications page, its more detailed.
Ford Bronco Price jump from 2 to 4 door on Base Model 1596749143657
