Hello fellow Bronco friends (glad we're not doing the Jeep wave right?)
I've had my 4dr MIC 1.0 hard top for over 6 weeks. Took delivery on Dec 1st. It's been 6 weeks of enjoyment every time I drive this rig. Found the right Ski rack (posted here in the forums) for my outdoor winter adventures. Last weekend I got the dreaded annoying rattle from my top that TFL and others have reported. Read a few different fixes found here (forum search results) but didn't like the idea of having loose foam as a solutions.
So I used Scotch 3M Heavy Duty 1-inch Mounting Squares (amazon link) that I had laying around the house and sure enough it worked like a charm
This simply solution provided enough padding to eliminate the rattle and now I'm back to a rattle roof free ride, thought some of you might like this more long term solutions vs foam.
Here is how to perform the solution for a few bucks and 5 minutes of time
The cause for the rattle is above the door on the front roof section in the back corner pictured here: (this is a picture of the foam solution that is just free standing and will fall out when you take off the top)
Step 1: Remove the front tops and apply double sided square on the top section of the roof where the plastic guide bolt thingy penetrates (haha) and causes the rattle noise
Step 2: Cut out or puncture a hole in the tape area like so
Step 3: put the tops back on and enjoy a rattle free ride solution that stays in place when you take on and off the top. Enjoy!
