CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
mcinfantry
Lee
Louisiana
Badlands 2 door
The tan top on the eruption green with tan seats is what i want. I need to sell my black top!
mcinfantry
Lee
Louisiana
Badlands 2 door
Mac92gli
PA
Bronco+minivan+miata
Thinking about getting this top because after a mere 2 weeks my wife is unhappy with how difficult it is for her to open and close the factory soft top. We also can't pull into the garage with the top halfway open. This top appears to solve both problems. And I dig the fastback look.
Seeing a lot of posts about vibration noise on the highway, but can anyone tell me if it's worse or similar to the factory soft top? Seems like everyone here started with a hard top.
Thanks!
Mscdman
P
Denver
OBX
putting back on my hardtop for the fall and winter tomorrow and can’t remember how the brackets on the 2-door went on :(. Does anyone have photos of what it looks like ???
STX Bronco
South Texas
F150 SuperCrew 22 Badlands
Arrows pointed up front and on the inside. Line up the 3 bolt holes and you got it. I would make them hand tight and then test fit the two front sections to try and center the pins. If not you will get a lot of clicking from being not centered. Pretty simple deal tbh.
Mscdman
P
Denver
OBX
Thanks. When you say inside you mean the bulk it bracket sits inside the vehicle right?
HeliPilot
Kenny
CT
2022 2.7L SAS
Thanks!
I used my 2 door Havoc top all summer. The retainer clip provided with the top only worked so, so. It allows for a lot of movement. I removed that clip strap, and installed 2 Velcro Cinch Straps (one on each side). This eliminated all of the movement encountered when the top was folded back. My top worked great and was reliable all summer.
Squatch
Miami
Do you have a picture of your solution?
HeliPilot
Kenny
CT
2022 2.7L SAS
I would send a pic, but I’ve already removed the soft top for the season. Below is a pic of the strap I removed, and what I replaced it with. I put the cinch strap in the same location I removed the original clip strap from. And I also added another one to the passenger side in the same location. Only needed to make minor modifications to the cinch straps by slightly drilling out the eyelet holes in order for the bolt to fit through.
Ford Bronco Rampage TrailView Fastback Soft Top for 2 door Bronco -- installed first impressions & photos IMG_0261
Ford Bronco Rampage TrailView Fastback Soft Top for 2 door Bronco -- installed first impressions & photos IMG_0264
Ford Bronco Rampage TrailView Fastback Soft Top for 2 door Bronco -- installed first impressions & photos IMG_0265
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
So I installed this top on my two door two days ago. Took about three hours; 90 minutes of which was figuring out the Guangzhou destructions for mounting the two rollbar brackets over the front seats.
I've never had a ragtop before; drove it at 75 MPH with the windows shut and it's not too bad.
The question is; how do ya'll store the rear window?!?
Just flip it up under the velcro cover on top?
Completely remove it (unbuckling THREE buckles) and store it in the bag?
WTF do ya'll do with the tailgate bar?!? I haven't tried, but I bet it does not fit in the bag?!?
Do I have to slide the bottom of the rear window out of the tailgate bar? Because reinstalling that is a PIA!!!
Overall I like the top, instructions need some work.
I would post some pics, but admins won't let me.
STX Bronco
South Texas
You can store al 3 windows in the provided bag (there is 2 dividers of soft material to keep from scratching the windows) and slide it in the Velcro flap up top, there is additional Velcro to keep it in place up there towards the front. The tailgate bar just stays in place in the rear. Once you do it a few times you will get the hang of it.
It’s a pretty simple but effective design. Being all self contained is great, I can have the windows out and stored or put back in in less than 20 mins.
CMillBronco
Craig
Yes as STX said just remove the rear window bar from the window and put it back in place. Be very careful how dirty and how you store the windows if they rub together dirty they will scratch very quickly. One product I've used for decades is Plexus for the windows works great and removes minor scratches and dirt.
