TN Bronco
Nashville, TN
2014 Range Rover Sport SC, 2005 Mercedes G55
Meant to send a thank you long ago. I followed your lead right after you posted the video and it turned out great. Took me quite a bit longer, but I was super cautious about breaking or scratching anything and trimming the lights was a pain. Great video. Thanks.
TN Bronco
Nashville, TN
Anyone add the raptor lights and either Baja or Diode amber fogs? Was wondering how close they may be in color and/or with the Diode amber backlights. Any other pics with amber fogs? Thanks
bwomp91
Brad
2019 Ranger
Yes very easy find desired circut,remove fuse from fuse block,replace with one of these,it will be the power either keyed or hot always on whichever you decide..
more dumb questions from me. Did you end up doing this? I mirrored OP’s instructions but am still interested in having them tie into something where they would be on when the vehicle is remote started.
Basically everyone else gets to enjoy them when I drive, but I never get to see them on since the vehicle has to be fully on (not just remote started) for the Aux switches to throw power
Would love to know if you did this and which you tapped into. Thanks!
PS - huge thank you to OP. Super easy install thanks to your guidance.
TX-Hans
I finally got around to doing this mod. I used an add a fuse tap (Micro 2 size) to tap into the engine compartment fuse block. I ended up piggy backing on Fuse #22, which is the 360 degree camera and is active when the ignition is on and illuminates when doing remote start. It's a 10 amp fuse.
My current challenge with the add a fuse tap is getting the fuse box cover back on and sealed; the wire exiting the box gets in the way and there does not seem to be a designed exit point. Working on/looking for a solution.
Overall, this is nice add-on and I like the end product but it took more time/work than I expected and more than perhaps it's worth. But, once I got going into it, it became more of a conquest to get it completed and looking good. Used PET sleeving for the wires with shrink wrap to keep it all neat.
Ford Bronco Raptor Grill Lights Installed & How To DIY 1647820342291
Assignment of the fuses in the engine compartment (2021-2022)
â„–Amp. RatingProtected Component
130ABody control module - battery power in feed 1.
330ABody control module - battery power in feed 2.
430AFuel pump.
625APowertrain control module power.
730APowertrain components.
820APowertrain components.
920AIgnition coils.
1340ABlower motor control module.
1610ARear windshield washer.
1830AStarter motor.
2110ANot used (spare).
2210A360 degree camera module.
2310AAnti-lock brake system run-start feed.
2410APowertrain control module.
Power steering module.
2510ABlind spot information system.
Rear view camera.
Adaptive cruise control.
Driveline control module.
2615ATransmission control module.
2860AAnti-lock brake system valves.
2960AAnti-lock brake system pump.
3030ADriver power seat.
3130APassenger power seat.
3220AAuxiliary power point.
3320AAuxiliary power point.
3420AAuxiliary power point.
3640A2021: 150 watt DC/AC inverter.
3830AHeated seat module.
4230ATrailer brake control module.
4410ABrake on-off switch.
4620ASYNC module.
5040AHeated rear windshield.
5440ADriveline control module.
5530ATrailer tow park lamp relay.
5820ATrailer tow backup lamps.
6030AUpfitter switch #1.
6115AUpfitter switch #2.
6210AUpfitter switch #3.
6310AUpfitter switch #4.
6410AUpfitter switch #5.
6510AUpfitter switch #6.
6610AStability bar disconnect module.
6930AFront windshield wiper.
7130ARear windshield wiper.
9140ATrailer tow light module.
10020ALeft-hand headlamps.
10120ARight-hand headlamps.
10730ATrailer tow battery charge.
12010AFuel injectors (2.7L).
1245ANot used (spare).
12510AUSB smart charger 1.
1395AUSB smart charger 2.
1405ANot used (spare).
1415ANot used (spare).
14620AAmplifier.
15810AStability bar disconnect module run/start.
16010ASmart data link control.
18260ADriver door module.
18360APassenger door module.
20260ABody control module B+.
21030ABody control module start stop.
bwomp91
Brad
2019 Ranger
430AFuel pump.
920AIgnition coils.
1830AStarter motor.
Rear view camera.
4620ASYNC module.
14620AAmplifier.
Did this today - THANK YOU! I’ve loved this mod but now it’s even better since it’s on with autostart.
Ground_zero298
Scs michigan
Thanks man! Got mine done today. Used a soldering iron to cut them, install, then melt them to the grill. Went with the clear version.
Appreciate the write up!
White light link. $7.89 each
https://www.amazon.com/gp/aw/d/B014IJ6OCG?psc=1&ref=ppx_pop_mob_b_asin_title
Used the harness out of this kit. Just soldered the pig tails onto the new light. Has enough to get the the drivers side fire wall. Lights are way to small for the grill.
https://www.amazon.com/gp/aw/d/B09PTPHXKH?psc=1&ref=ppx_pop_mob_b_asin_title
Ford Bronco Raptor Grill Lights Installed & How To DIY 2F3D22B1-1AC1-4489-A08F-0A5998464B1F
Ford Bronco Raptor Grill Lights Installed & How To DIY C1E650E1-EC8C-4A53-B47C-F2D860CEC943
TX-Hans
Was comparing these to another recent similar product entry and I'm liking the smoked amber better. In fact, was just outside walking by my Bronco and noticed when off, they blend into the shadows of the grill and when on they have a nice amber glow to them.
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
rcloke0124
Robert
2022 Ford Bronco 4-Door, Sasquatch
Just installed these today. Easy install, the only advice I’d offer is to be gentle with the plastic caps that hold the radiator cover and to make sure you pull on the top piece of the cap itself and then the bottom.
They really do look great.
fresnobrianb
2021 Bronco Badlands
These lights and what they are supposed to stand for have been rendered meaningless by all the fuckin bros who wanna look like they have a Raptor at night.
Most people have no idea what they are actually for
Oh shit. My Bronco is wider than 80”, am I required to have them?? Ya’ll are hilarious. A Raptor is 80 inches wide and an F-150 is 79.9 inches. I own neither, and in fact this Bronco is my first Ford I’ve ever owned. But it’s not lost on me that .1 inches is important to owners of these trucks. Lol.
Cbiggs
Cory
These are the diode SS3 Pro’s. Definitely more yellow than the Baja.
adrencg
Bronco Badlands Sport
Would it be ok to tap into the headlight fuse for the raptor lights?
TX-Hans
I don’t think it will create any issues. Should work fine.
adrencg
It worked to tap into headlight on fuebox, but it worked too well. The raptor lights went on and stayed on even with the vehicle power turned off.
I ended up taking out my headlight and using a vampire tap into the parking light wire.
