Raptor telling me my hood is Ajar when it’s closed?
vick
Vick
Atlanta
Telluride
I am little frustrated less than 300 miles. I have opened and closed it a few times and it doesn’t go away.
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
I saw this once any it was it wasn’t closing hard enough. I basically had to let it drop once I was 3/4 of the way closed. Not saying this is your issue but may be worth a try. If not it’s an easy fix at the dealer but of course no less frustrating
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
Screw in the little stoppers at each corner on the rad support a little bit. This will let the hood close further and fix your issue. A lot of us with regular broncos had that issue
Obiwan
Southwest
Don't care to share personal info
Is it just a momentary switch on a bracket of some sort? Where is the hood switch located?
JonD
Jon
Maryland
Suburu Outback
Had same issue on Wildtrak usually only happens on highway, but hasn't happened in awhile
akturbo
Seattle Eastside
'21 Bronco, 3500HD Chevy, Rav4Prime, Turbo Skidoo
Yes! Where is the switch? Mine does this, I just shut it harder and it goes away. It’s happened a few times but luckily it doesn’t stay on.
vick
Vick
Atlanta
Telluride
I think the issue has fixed. Closed it tighter
drewgolson
drew
birmingham,al
21 antimatter blue obx (sold) 22 badlands mt
This has happened to me less than a couple hundred miles in. Randomly the sensor dings driving down the highway. Hopefully it doesnt become an issue.
vrtical
Doug
GSMNP, TN
Fords
adjust your hood stops lower.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Hood stops lower. Ours on the Wildtrak was triggering the alarm every so often. But turned a Quarter turn on the stops and no more random alarm triggers.
Obiwan
Southwest
I'll ask again, where is the hood switch? Is it a momentary somewhere? Is it built into the hood catch itself (worse design). They usually have some adjustment to them but purely depends on what type of switch it is and where.
Rjacks258
Randy
Punta Gorda, FL
It’s right there in the latch, not sure what type of switch it is, but it is there no adjustment that I noticed. I gave it a quick look and that’s all. (My post above) it only started doing that after I raised the hood stops to tighten the hood.
