Rattle and Popping Noises from B pillar
JonathanDuong
Jonathan
Ford Bronco First Edition
Does anyone else have a rattle and popping noise that comes from the passenger B Pillar?
I can't determine where it's coming from exactly, but it's near the B Pillar and seatbelt housing area.
I drove with the seatbelt tugged and it still has a hard plastic to plastic popping noises on small bumps.
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
MIC top?
Do a search?
dwayle
Del
US
F-150
I've got what sounds like a marble rolling around in the rear passenger area. I figure that they dropped a screw behind the inside plastic body panel on the passenger side. I'm waiting for someone to do a youtube video on how to take apart the interior before I try to find the source. I have bad luck with breaking things when I try without instructions.
Jr87mustang
Josh
Northern Cali
Its the pin that drops through the alignment hole right behind your head. If it doesn't center on that hole perfectly it rubs on the side and causes the popping noise.
JonathanDuong
JonathanDuong
Jonathan
I'm sorry I am new here and not sure how to reply to certain replies. I have a 4DR MIC Hard Top. I've removed the front and rear seat hard tops and still hear the sound. For $70,000 this is quite annoying, on top of the recirculating air that keeps turning off. Ford states it can only turn on if the Max A/C is on. I know I have a spoiled California weather but it's cold for us and we need heat...
Which brings to my next issue about that. The heater keeps opening up so my 1/4 in crack in the windshield has expanded to about 11 inches now with the hot air inside and cold air outside. Roughly 2 weeks to get the windshield in... Watching it expand more and more everyday.
JonathanDuong
JonathanDuong
Jonathan
MIC top?
Do a search?
Sorry, just saw a reply button. I did, and everyone plus Ford themselves said it was the MIC hard top. However with the top off, I can still hear it in the passenger seatbelt and B pillar area.
JonathanDuong
JonathanDuong
Jonathan
That's horrible! I've had somewhat the same in my Silverado that came from the dash board. I removed the entire unit and still couldn't locate it. Turns out, it was the windshield wiper fluid housing that was loose, haha.
JonathanDuong
JonathanDuong
Jonathan
The sound started randomly but I haven't took the top off until I try to discover where the sound came from. After taking off the front two rows, I still hear it from the passenger B pillar. It's very annoying...
Ksjrb03
Tx
F250
It’s likely the airbag covers on the roll cage. I had one that I needed to snap into place correctly. Be careful, the interior plastic panels are thin with flimsy connectors.
JonathanDuong
JonathanDuong
Jonathan
Everything I pressed on felt firm and secured, except the plastic housing on the lower B pillar that connects to the floor. I tapped it a few times and it doesn't duplicate the same sound I hear when in motion. I should check out the air bag area that you mentioned or get a young set of ears to try and determine the location. Thanks!
Ksjrb03
Tx
F250
I’ve had a never ending battle with rattles and pops in mine. It can definitely play tricks on you, not where you think it is from the drivers seat. My wife is getting tired of driving down bumpy roads with me crawling around the back and cargo area 😂
JonathanDuong
JonathanDuong
Jonathan
We're all on these forums trying to figure out what Ford should be figuring out with the bumper to bumper warranty...
