Yes- but in an Amp meter- each pair (in SPOT OR FLOOD ONLY- not with DLR on) only pulls 2.9 amps… so you are under the 10 amp limit for switches 4,5 and 6. I’m wired to switch 5 and haven’t popped a fuse yet.
I’m curious about this as well. These lights look great. I’m thinking I’ll get the Amber DRL option and just wire those in to the headlights. Then I’ll put the white lights on one of the upfitter aux switches.I'm looking at buying a set of these. Anyone have any comment on if they got the spot or flood version? I'm leaning towards spot because I spend a lot of time on rural back roads and want to see far, but also want to see deers
sounds like all the DRL options are spots by default.
thanks!
I got the floods. They're super bright but I've only tested in a few dark spots so I can't say much about how they would perform on a rural road.I'm looking at buying a set of these. Anyone have any comment on if they got the spot or flood version? I'm leaning towards spot because I spend a lot of time on rural back roads and want to see far, but also want to see deers
thanks!
I got the floods. They're super bright but I've only tested in a few dark spots so I can't say much about how il they would perform on a rural road.
It might be possible give the low amp mentioned above but I was lazy and used an AUX switchany chance these could be wired into my factory fog switch?
