RCV Performance CV Axles - are they junk or did I get a defective set?
rtaylor
rtaylor
R
ID
19Raptor, 22Bronco
Hopefully the others in here will keep their experience updated and ill try to do the same till we find a solution.
RCV received my axles, inspected them, and "authorized refund". Unfortunately, they didn't provide any additional information. I heard this through the merchant (not directly from RCV). I expected the merchant to offer replacement axles instead of refund since they have more in stock, but they didn't.
Photos (after removal). 12/21 and 3/22 date codes on sub-assemblies. I'm not sure the RCV c-clip holds as securely as stock (seemed easier to pry out the RCV axles than the stock axles).
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? IMG_1194.JPG
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? IMG_1206.JPG
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? IMG_1202.JPG
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? IMG_1210.JPG
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? IMG_1203.JPG
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Can any of you confirm how many splines and the width of the axles? Currently have a bad cv m190. And am interested if I can upgrade to these. As they only list for the m210. (Obviously I would want to wait until they figure out the problems.). Currently in discussions but the dealer does not know if I can upgrade or not without actually installing the m210.
rtaylor
rtaylor
R
ID
19Raptor, 22Bronco
Different part number for m190.
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? 1659486685494
2bigbronco
Shane
Prunedale ca
2022 bronco
Interesting as neither of my sets came with c clips and I re-used my stock ones.
Off to see if I can see a date on one of my pics
Edit... yep, same date.
Where did you get your set from?
rtaylor
rtaylor
R
ID
19Raptor, 22Bronco
I guess that confirms that the c-clips aren't related to the problem.
The vendor has been easy to work with.
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? 1659499775550
Tcarp1
Travis
Newcastle, CA
2021 2 Door Badlands
I was a little worried after reading this thread, but I installed a set of RCVs this last weekend and they have no issues thank goodness. Date codes were 3/22 on the axle shafts and 5/22 on the cv bells.
Aztec1382
Sam
F350
Maybe they had a bad batch
Have ran rcv on rzr and can ams
Always top notch stuff
75bko
Kevin
Clovis, CA
1975 Ford Bronco
From what I've heard, RCV had a recall on these.
Digger 5
PNW
Jeeps
Both m190 and m21O have 29 spline shafts. One side m190 is the same as the m210. Not sure which side but I'm guessing it's the right side due to the intermediate shaft.
Felix808
SRV CA
Not sure about a recall. When I reached out to them they weren't sure if mine fell into that particular production run, but would swap them out if any problems (I ordered direct). Mine also had the snap rings that were missing on a few peoples axles. I have not had a problem yet. 🤞
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
I installed a set of RCV Performance CV axles for M210/sasquatch (CVJIFS-BRONCO-S).
They were smooth in 2H, but in 4A they had severe issues on test drive. I think they were binding internally with loud thumping and extreme vibration under load. It was intermittent, but very repeatable (would always start thumping after cornering). I reinstalled the stock axles and the problem went away. I have Icon coilovers (~2.5").
I tried to contact RCV Performance, but no response so far (2 days).
Update: I finally heard back from RCV Performance. They offered no explanation, but stated that my only option was to return them to where I bought them.
Has anyone successfully used the RCV axles for Bronco? I am wondering if I received a defective set, or if they are junk.
Just got my RCV's in late August and installed them last week. They worked in 2WD but the first time I put them in 4LO I heard a low growling from the driver side. Nothing noticed in 4 HI or 2WD. Made it home and checked out the driver side and saw this...... Guess mine are bad too. It flung grease all over the wheel well.
popo_patty
Caleb
Sacramento
Just heard back from the dealer, RCV axles for the Ford Bronco are all recalled. They are no longer selling until they figure out the design issue and fix it.
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
Did I miss the pandemic of breaking CV shafts somewhere?
Don't ge tme wrong, I love my RCV's but what's the point on this platform, they don't seem to be an issue...
Ford Bronco RCV Performance CV Axles - are they junk or did I get a defective set? 1663279613915
0ne
Nate
CO
Flex
Not on their website as of today
popo_patty
Caleb
Sacramento
I keep regularly checking in with RCV and they told me as of a week ago they still have not come up with a fix... Sucks because I'm a sucker for overbuilding my Rigs and want their product hecka bad... I had their CV's dated 3/22 as well and they were a bad bunch and I got a refund for them. Been waiting for months now... The Spicer's are becoming more tempting but at $500 more and no warranty like RCV its meh still.
