Anyone service their rear brakes yet? And if you have done it what was the procedure to reset the rear caliper? If you have let the dealer do it for you, what did they charge you for the rear brake service?
Makes sense to me. Apparently the problem is when the electronic park brake decides to set itself with nothing to clamp the pads against. Gonna have a bad time.I still can't get brake maintenance mode to work.
Not sure if it's because I have a 2.3 and/or the 7MT. I suspect it just isn't a thing on the 2.3 because we have the old school vacuum brake booster instead of the electronic one - but could never confirm it.
Yeah, very true. The 2.3 and 2.7 have the same e-brakes though, which was why I was trying to get it to work in the first place. But yeah, just pulling the battery cable more or less fixes that problem.Makes sense to me. Apparently the problem is when the electronic park brake decides to set itself with nothing to clamp the pads against. Gonna have a bad time.
On ours after the portal installation we had to do a full bleed. I have one error coming up intermittently that refers to insufficient or overpressure in the system. It isnāt there upon start up and randomly comes on with city driving but also goes away. This was with old school pump and hold bleed method. Iām feeling like thereās a tiny bubble in the front brakes somewhere that Iām just not able to clear the old way, so I ordered a venturi style bleed system and will try that out when it shows up.Yeah, very true. The 2.3 and 2.7 have the same e-brakes though, which was why I was trying to get it to work in the first place. But yeah, just pulling the battery cable more or less fixes that problem.
I haven't had to bleed the brakes yet, like the OP is asking - I have heard you either need Brake Maintenance Mode and/or FDRS to do that... wonder if it's the same way on the 2.3s or if you can old school bleed them just fine?
I remember a post here where someone did replace the rotor and bled them, said the brake pedal felt fine and braked fine, but they couldn't get an error code to clear until they hit a button on FDRS. Didn't catch which engine he had though. Kinda makes sense with the EBB - it may need a recal or something. Not sure it applies with the vacuum booster or not, but knowing Ford - probably.
