Rear Seat Belt Issue - not retracting
Teejay3726
TJ
Houston, TX
2021 Badlands & 2022 Bronco Raptor
Admittedly I have two rough kids in boosters, but I’m having an issue with the rear seat belts. They simply aren’t retracting anymore. The upper will retract slowly if I feed it into the panel.
I’ve checked and there is no kink in the belt. Anyone have an easy fix? Anyone experienced this?
2021 Badlands 4 Dr
AZMikeL
AZ
My fronts were doing that. Turns out the hanger needed some cleaning out.
Tried with q-tips and some alcohol with no luck. Then grabbed my multi-blade feeler gauge out of the toolbox and ran a blade above and below the belt thru the hanger. Fixed it right up. You may need to clean the belt as well if there's kid muck on it.
I also had 2 buckles that would not spring back when pressed causing the belts to come undone randomly. Wrapped in a rag then used alcohol/q-tips to clean until it got moving right again. You kinda have to pour some in to get it fully clean - thus the need for the rag to soak up what comes out of the bottom. Finished with some silicone lube spray. So far, so good.
