Rear seat delete on 2 door Bronco
Andrew_EOD
Andrew
Panama City
Ford Focus ST
OOoo. That is what I plan on doing. Well, probably one seat at least. From what I've read, it's not an overly complicated process, but some bolts do stick up from the frame. I want to see what Goosegear comes up with. A nice flat platform with extra storage and whatnot would be great.
Bronc-itis
E
South Florida
Q50 (bronco soon)
I’m already planning for this. The key for me is to find a seat delete kit that doesn’t prevent me from storing the panels and doors in the back. The back seat and cargo area are going to be for dog and gear. Should lose a decent amount of weight from removing the seats. Hopefully more than the delete kit adds.
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
There will be studs sticking up from the floor with the seat removed. Someday when I get mine I'm going to make my own "delete" via a pullout platform similar to what goose gear does, but make it way better than they do for way cheaper.
Bronc-itis
E
South Florida
Q50 (bronco soon)
Yup. More than likely Goose gear will use the existing bolts to mount their delete kit. Definitely better than trying to remove them.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Cut off wheel!
RG7
B8 A4, 2018 Triumph Street Triple R
I think it will be several months before we really start seeing people ripping into their Broncos. Personally, my rear seats are coming out the first weekend I have it.
We know what the rear of the tub looks like, and know the studs are there. There’s really one way to level the rear (plywood, or starboard if you’re feeling spendy). And a few ways to deal with the studs.
1). Use them as mount points after you drop in your plywood if you’re building any kind of organization system in the back. This is my plan and I think they’re actually an unintended gift from Ford that we already have pre placed mounting points.
2). Drop in your plywood and then cover the studs with some sort of sloping, rubberized polymer piece. I’m envisioning either something cylindrical that sits on the studs or something that takes the shape of a field cone with sloping edges. This would be the solution if you’re looking to haul larger items in the back that you’ll be taking in and out.
mikey_photo
Allentown, PA
2021 2dr Badlands
I reached out to Goose Gear asking that exact question and they intend on making a rear seat delete for the 2 door. I can’t wait!
Below is the response I got:
Carolina Jim
Highlands
2021 Bronco 2-door
I look forward to following your progress, as I want to make my 2-door much more dog-friendly. Those studs look to be ~2" high; I'd hate to remove them and lose the ability to reinstall the seats.
RG7
Blaven
Pennsylvania
2021 Jeep Gladiator Willys
I'll let them work out a blueprint on my 2 door if they give me one for free when they start to manufacture 😁
International_George
George
Kirkland, WA
1980 International Scout II
What about a rigid foam board from HD? Could get that in 2” thickness with no weight gain. Carpet one side and voila! Not sure if it would squeak, but it’s not expensive to try it out. I may explore it on my 2dr since I really don’t need the rear seats.
Advertisement
Advertisement
