For reference, I have a 2023 2 Door Badlands Lux with the B&O stereo setup. Any help from the stereo gurus
@RagnarKon @Brian_B
Has anyone installed the Musway Two100 amp or any other 2 channel amp to power the rear pods with the B&O setup from Ford? I also have a Kicker Key 500.1 running the sub. I purchased both amps and the Plug n Play adapters from plugnplaykits.com. Install was easy just now confounded with this hissing….
I mounted the Musway under the steering wheel and the Kicker in the back space on the passenger side toward the tailgate.
Kicker location
I have tried the ground above the Driver side speaker.
I have tried drilling and dremmeling off the paint at spot close to that ground. Per Joe @plugnplaykits I have moved the ground to the brace that holds the amp under the steering wheel. All three grounds still give off the same low hissing noise when the Bronco is opened and for a few seconds until the Bronco goes into sleep mode when closing the door.
The hissing isn’t terrible and I’m not sure if it’s affecting the sound quality, but it is noticeable to me in the drivers seat and to rear passengers.
Any help or advice would be greatly appreciated as always. Thanks!!!
Kicker location
