dgorsett
colorado
F250, Mustang, Explorer
Front axle lube capacity higher on non locking non FAD than with FAD, meaning the FAD is in the differential case. North7 shared a photo that implies this but I believed it would be Indiidual Wheel Engagement (IWE). Really this only applies to the non Sas BB and a few OBX w/o adv 4x4, so I'm probably the only one who cares, but interesting.
peta8368
Norwalk, CA
2016 Polaris Slingshot
What about the coolant capacity difference on a 2.3, between 7mt and 10at? does that mean coolant flows through the 10at for cooling? I can't imagine that's a packaging difference ..
Peter
MayhemMike
Mercury
The 2.7 has a Motorcraft 2026A “ cartridge” for the oil filter.
Dogstyle
Marc
Ontario
2016 F150 Sport 4x4
Via BN:
Components
2.3L ECOBOOST
MOTORCRAFT PART NUMBER
2.7L ECOBOOST
Air filter elementFA-2022FA-2022
BatteryBAGM-94RH7-800BAGM-94RH7-800
Cabin air filterFP-93FP-93
Engine oil filterFL-910-SFL-2062-A
Spark plugSP-578SP-578
Transmission fluid filterFT-218FT-218
Windshield wiper blade (front)WW-1703WW-1703
Windshield wiper blade (rear)WW-801WW-801
Engine Oil
Capacity (including the oil filter) for the EcoBoost engines:
  • 3L: 6.2 quarts
  • 7L: 7 quarts
2.3L ECOBOOST
2.7L ECOBOOST
SAE 5W-30 Synthetic Blend Motor Oil (U.S.)WSS-M2C961-A1WSS-M2C961-A1
Extreme cold (-22.0°F) alternative:
SAE 0W-30 Synthetic Blend
WSS-M2C963-A1WSS-M2C963-A1
Coolant
Capacity for the cooling systems:
  • 3L w/ automatic transmission: 10.5 quarts
  • 3L w/ manual transmission: 9.6 quarts
  • 7L: 12.4 quarts
2.3L ECOBOOST
2.7L ECOBOOST
Motorcraft® Yellow Prediluted Antifreeze/ Coolant (U.S.)WSS-M97B57-A2WSS-M97B57-A2
Fuel Tank Capacity
The two- and four-door models’ tanks hold:
  • Short wheelbase: 17.4 gallons
  • Long wheelbase: 21.1 gallons
Air Conditioning
All Broncos’ AC systems hold 19.4 ounces of refrigerant.
SPECIFICATION
R-1234yf Refrigerant (U.S.)WSS-M17B21-A
Motorcraft® R-1234yf Refrigerant PAG Oil (U.S.)WSS-M2C300-A2
Washer Fluid
The manual doesn’t say how much the washer fluid reservoir holds, just to fill as needed.
Motorcraft® Premium Windshield Wash Concentrate with Bitterant (U.S.)WSS-M14P19-A
Transmission Fluid
The fluid capacity (approximate dry fill. Actual amount could vary during fluid changes):
  • Manual transmission: 2.4 quarts
  • Automatic transmission: 13.1 quarts
ManualMotorcraft® Dual Clutch Transmission Fluid (U.S.)WSS-M2C200-D2
AutomaticMotorcraft® MERCON® ULV Automatic Transmission Fluid (U.S.)WSS-M2C949-A, MERCON® ULV
Brake Fluid
Capacity: the clutch and brake systems’ quantity is listed as “Fill as required.”
Motorcraft® DOT 4 LV High Performance Motor Vehicle Brake Fluid (U.S.)WSS-M6C65-A2
Transfer Case Fluid
The T-case holds:
  • 4×4 with part time engagement: 1.3 quarts
  • Advanced 4×4 with 4A mode: 1.6 quarts
Motorcraft® MERCON® LV Automatic Transmission Fluid (U.S.)WSS-M2C938-AMERCON® LV,
Axle Fluid
Front axle fluid capacity:
  • W/ electronic locking differential: 26.2 fluid ounces
  • W/o electronic locking differential and w/o front axle disconnect: 29.2 fluid ounces
  • W/o electronic locking differential and w/ front axle disconnect: 30.4 fluid ounces
Rear axle fluid capacity:
  • W/ electronic locking differential: 63.6 fluid ounces
  • W/o electronic locking differential: 65.3 fluid ounces
Motorcraft® SAE 80W-90 Premium Rear Axle Lubricant (U.S.)WSP-M2C197-A
Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant (U.S.)WSS-M2C942-A
Thank you for the update.
Blk Diamond Cheese 2 dr/Sasq/2.7L/MIC/Mid pk/Tow pk
dgorsett
colorado
Peter
Unlike many transmissions that route fluid to the radiator to cool, the Bronco routes coolant to a heat exchanger mounted to the transmission, hence more coolant. There is a photo in one of the transmission threads, but I couldn't find it.
2.3BigBend
PA
Work Beater
5w30...thought they might have moved to 5w20 that my last few fords have ran.
Cool, thanks as I know what to get now...sticky this for future reference maybe?
I expected 5w20. Odd.
Idk what DCT fluid is but it doesn't belong in a manual, it was painful enough having to put ATF in Ford's older manuals.
I think all the "regular" EcoBoost engines except some of the 3cyl in Focus, Escape, EcoSport take 5w30?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Nope, I noticed that too. Very curious, especially since IWE has become so common on Fords.
An 800 CCA AGM battery is a nice surprise :cool:
xcxv
hmm
Jeep Bronco
2.3 oil filter vs 2.7 oil filter
2.7 oil filter looks a lot bigger and newer design (and 2-3x more expensive)
BCFDLtE13
Wayne
Manchester, MD
2015 Mustang GT Performance Pack
[/QUOTE]
It's for a Dual Clutch Transmission, and I agree it does not belong in a manual. Getrag Manual Transmissions are a bit finicky when cold. The MT82 6spd in the Mustang calls for the same fluid. It was to address complaints of a "notchy" feeling when shifting while cold.
I run amsoil MTG (Manual Transmission Gear Oil) in my Mustang. It is still a bit "notchy" when cold, but greatly improved. This notchy feeling is actually the synchronizers and should and can be avoided. A quality oil and deliberate slow shifts or double clutch shifts are required when cold. Once it's warmed up a few miles, smooth as silk.
Bdisco
Flashing my lights behind you, MA
‘88 911,‘15 Chevy 2500, ‘24 Acura Integra Type S
Do we know the recommended intervals.
3k, 5k, or 7.5k?
Is motorcraft full synthetic, blended, or Pennsylvania crude?
Bronco Don
Don
Rialto, California
Tacoma 4x4
I’m getting the 2.7 and it seems the oil filter is on top of the engine, if thats true that’s like my Tacoma and a breeze to change. All so I’m going to use full synthetic in mine I hope that will be ok.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
3k, 5k, or 7.5k?
Probably uses an oil life monitor with 10k max life. I'll use mobil 1 full synthetic.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Discussed this with Redline a while back, DCT fluid is closer in viscosity to an ATF, but with the antiwear additives like an MTF. A DCT is pretty much two manual transmissions in parallel, anyways. Speccing out DCTF in a manual trans happens a lot, it's what is in the GS6-45BZ manual in my M235i.
Efthreeoh
Hummer H3T
I'll mark this thread so I can refer to it in 2028 when I need to do some service on my Bronco...
