Redline Tuning Hood QuickLift System now available at Panda Motorworks!
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
Eliminate your Hood's prop rod today with the Redline Tuning Hood QuickLIFT system. Progressive gas springs will lift and hold your hood without the need for a poorly placed prop-rod, simply start to lift your hood and let our QuickLIFT System take over. Your hood will lift and hold firmly at the raised position. This QuickLIFT system is designed for the full size Bronco only.
Ford Bronco Redline Tuning Hood QuickLift System now available at Panda Motorworks! 21-11039-02-10T
This is a bolt in system that anyone can install. The installation manuals can be downloaded for full color images that will walk you through every step. 15 minute installation time - minimal skill level required and you will only need a socket wrench with both 13mm standard & deep-well sockets. This system uses all stock or existing locations to attach the gas struts (no drilling required).
This QuickLIFT System is considered the Max Lift Edition. The hood will raise about 8" higher than stock prop-rod height, which is where it should be on this vehicle.
QuickLIFT PLUS - This is the all-black system... it includes black powder-coated hardware with progressive rate gas springs with a special black e-coating and a 4 year warranty. Your hood will raise from mid-lift and remain open higher than stock prop rod height. This system is CAD designed and ships from our facility in Ann Arbor, Michigan.
Ford Bronco Redline Tuning Hood QuickLift System now available at Panda Motorworks! gas springs - black strut pair
QuickLIFT CARBON - A popular add-on for the QuickLIFT PLUS Systems - real carbon fiber sleeves come pre-installed on the black gas struts. Only available as an option on QuickLIFT PLUS
Ford Bronco Redline Tuning Hood QuickLift System now available at Panda Motorworks! 41-00003-8T
  • Bolt in system - no modifications to vehicle required
  • Black powder coated hardware in QuickLIFT PLUS
  • Hood raises 8" higher than stock prop rod height
  • Prop rod can be removed once installed
  • Patent pending attachment system
  • Progressive, slow release gas springs - final few inches of operation, gas springs slow down extending rate allowing for a fluid lifting process.
  • Full color installation manual with every QuickLIFT system
  • 4 Year warranty on QuickLIFT PLUS
TheKim
Kim
Fusion
Happen to have a link handy to the item on your store?
Mitch
St. Louis, MO
TheKim
Kim
Fusion
Mitch
St. Louis, MO
Ah, sorry. Have dark-mode enabled and the links just looked like underlined text, but didn't have a certain color or anything to them that made me think "oh, that's a link".
Thanks for the quick and polite reply to my ignorance ;)
No worries at all, I'm happy to help!
Lindy08
Cliff
Illinois
2009 F-150
Does the Ranger stubby antenna you guys sell fit the Bronco?
Mitch
St. Louis, MO
Unfortunately it does not. We are working to find a stubby antenna solution for the Bronco!
P52Ranch
Oklahoma
2DR 7MT Badlands, F150 Lightning, New Holland 4030
Is the underhood insulation one of your products or did it come with a pre-production Bronco?
Mitch
St. Louis, MO
Thats a good question! This image came from Redline Tuning themselves, so I'm not exactly sure why or how they got the under hood insulation.
campbebc
Ben
Boulder, CO
2017 Ford Focus RS
Got my struts in directly from RedLine already, they seem like great quality and are a must for anyone that will ever be working on their own car. Went with the black option.
KTP 30
Ray
Southern Indiana
21 Wildtrak 23 Bas Squatch 93 Mustang 87 mustang
I ordered these from sendt an email to make sure my order was correct he told me they be sent out that Wednesday. 2 weeks later still haven't received had to email them and ask about where my order was at now they're on backorder for 3 for 4 Weeks offered ato refund my money but I'll wait would be nice to have on the website that this item is on backorder
Razorback
Dallas
Lincoln MKX
What's the difference between Quicklift plus and Quicklift Elite?
Edit: nevermind..found it. Just the material it's made of. I like the carbon fiber sleeve you guys offer with it...
BroncoKong Jr.
Andrew
Are these in stock or do they ship from Redline? Because Redline seems to be out of stock for a few more weeks.
