- Tim
- Feb 19, 2021
- 3
- 334
- 612
- Wet Side of WA
- Jeep JKU
- Base
Upholstery glue, which I can only imagine is what will be used here, will be a pain to remove. It can be done, but no guarantees on what the top substrate will look like when you’re done, or if the top will have any kind of reaction with the solvent you use to remove the glue. My thoughts are leave it off your order if you’re hesitant. Can always go with hotheads as originally intended
From a factory perspective, they wouldn't mess with the CoverKing tape strips, they are way too time consuming, spray in adhesive would be far faster.Aftermarket pieces definitely. Didn’t occur to me that the factory would be taped as well. Good catch
You're probably spot on.I don't imagine the oem headliner will come out without a fight and leave residue behind.
A heat gun and some Goof-off/WD-40 would get the OE liner out, but it would be a lot of work.
