Removing sound headliner if I don’t like it?
GiddyUp’21
New York
Toyota Highlander (2nd car while waiting 4 Bronco)
These headliners are most likely made from PET (recycled plastic bottles) and are washable. The biggest issue would be spraying it directly with a large amount of water, trapping water in between the liner and the top, thus making your Bronco smell mildewy if the water doesn’t evaporate in time. Worst case scenario if you over saturate it is to point a fan at the top or a hairdryer until it dries.
Is this the rationale for the default being no headliner with the MGV seats? I.e. the assumption that anyone with those seats will want to spray out the interior and water and headliners don’t work well together?
MacHudson
Northern New Jersey
2012 Edge
This may be a dumb question but why can’t we put the HH on top of the OEM sound deadening headliner? If the HH is installed with tape strips why can’t we just add it, if we need the additional insulation? I’ve never installed or used these items but from the Utube videos I’ve seen seems reasonable enough to be done that way.
You probably won't get proper adhesion from the factory headliner to the double-sided tape, to the HH headliner. It would be like putting tape on the carpeted office floor, or a felted surface, and then counting on that to be strong enough to hold the HH headliner forever when you turn it upside down.
I think that's how it would be. I've personally never been down that road.
Atomicdog
Eddie
Philadelphia
Yes, Ford stated in an email to dealers it was to preserve washout capability but I’m not finding the thread at the moment.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ford Bronco Removing sound headliner if I don’t like it? 63070E62-B661-4E67-B968-80EF4AEA54AF
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
If you have 4 door MGV then yes, that’s a likely future move. Netting on the doors isn’t going to hold a paper cup of coffee. It’s really foolish that the MGV lacks a proper backseat cup holder.
and yes, I know you were just having some fun
Off-topic:
I’m pretty sure those door nets are installed with Bronco bolts which are removable and made to facilitate easy substitutions. I’m sure either Ford or an aftermarket supplier will come up with a cup holder accessory panel to install there.
Ford Bronco Removing sound headliner if I don’t like it? 517DC9A8-EA1A-4725-99E6-7510156C3B95
