Ohnoohnoooo
St. Paul, Minnesota
BMW z3, Nisan rogue, joint-custody of Jeep YJ
I've got a couple builds in mind (another is a BL), but one is OBX + 33s + small lift, so I wanted to see what that may be. Here are a pile of photos (NOTE none are available as shown here, this is my retouching of B&P images). Made some as gifs for easy comparison. This is what I did:
• Added 17/33s to OBX(+ same lift as BL) + steel bumper
• Color-corrected the Cactus Gray using samples from real-life photos (I have seen it in person, but the contrasting colors are important in understanding how it will behave. The samples I used are from full-sun, shade, sunset and flat light). I used the lighting from the original to guide whether I matched the lighter or darker tones. See the gif :) For me, I wish it CG was the B&P and launch materials color, but that isn't the case. I want to see a bit of reality before committing, and B&P isn't going to fix it.
• "Made" a Shadow Black and Oxford White top.
• Also "painted" the OBX flares Shadow Black — it certainly gives the impression of a bigger space in the wheel well.
•And then as my 2.7, Lux and Shadow black will likely bump me to MY22, I made my wish-Bronco — Boxwood green with white top. While I am dreaming, the grill would be the Black Diamond one and white, and the interior saddle leather.
Not available yet, but I sure wish it was.
Hope this helps someone in their decision.
:love: Boxwood Green, OW top (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops boxwood green 2021 Bronco rendering 1
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops boxwood green 2021 Bronco rendering 2
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops boxwood green 2021 Bronco rendering 3
Boxwood Green, OW top, SB flares (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops boxwood green 2021 Bronco rendering 4
OBX + 33s (not color-corrected Cactus Gray)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_33s
color-corrected cactus gray, shadow black top:
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops CG_HEROSWATCH
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops CG_SIDESWATCH
Oxford White + OW top + SB painted OBX flares (33s):
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OW_FLARES
color-corrected Cactus Gray, Shadow Black top (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_HERO_33_CG_SB
color-corrected Cactus Gray, OW top (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_HERO_33_CG_OW
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_BACK_33_CG_OW
color-corrected Cactus Gray, SB top, SB flares (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_BACK_33_CG_SB_SBFLARE
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_SIDE_33_CG_OW
color-corrected Cactus Gray, SB top (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_SIDE_33_CG_SB
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_SIDE_33_CG_SB_SBFLARES
color-corrected Cactus Gray, OW top, SB flares (33s)
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops OBX_SIDE_33_CG_OW_SBFLARES
JGuske23
Justin
Kalamazoo
2019 Jeep compass
Great job! Love the details
ssolypop
Solomon
Hawaii
Avenger
OBX + 33s (not color-corrected)
This would be mine! thanks for the renderings
Ohnoohnoooo
Ohnoohnoooo
St. Paul, Minnesota
Great job with the technical achievement and thank you.
Boxwood should now be exposed as Granny Green, though.
Granny green for Granny Gear.
Here's Grabber and Mallard for you:
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops Grabber
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops Mallard
Ford Bronco Rendering: 2022 Boxwood Green and Cactus Gray OBX with 33s + white tops + shadow black tops Mallard_OW
Squatch
Miami
Gracias! I would take Mallard, but it's a bold color that would require Ford to take a risk and that's not very popular right now. I just hope that the green offered is closer to Mallard than Boxwood.
Loved my rarely used granny gear in my 79!
Kos
Omaha, NE
2022 Ford Bronco Badlands
I had assumed that you would need to paint the grill white to make the white top work, but it appears to work with the black painted in these mockups.
JPNC
Charlotte
2011 BMW 335i
Very cool! I love the Boxwood Green.
drive21bronco
North East USA
2021 Bronco Black Diamond
Nice!
mjjnuge
Josh
Indiana
Jeep
Nice work! I requested my res to be pushed to 22MY with the hope of a boxwood green, or similar, and pairing it with a white top and white grill, so I'm all about it
