- Wesley
- Feb 10, 2021
- 17
- 1,327
- 2,320
- North Carolina
- FJ
- Black Diamond
Welp
mine are here
mine are here
Looking forward to hearing your thoughts and seeing if your rear mat fits better than mine.Welp
mine are here
I’d take a carpentry knife and cut off a few rows of the nubs on the bottom near the door sill and see if it fits better.Just put them in.
Fronts are perfect.
Rears are about the same...the middle area of the rears looks good, but each side near the door sill is slightly raised.
So, now looking for a solution......3m tape? hook and loop? No idea, but would like some ideas.
Do you think some heat will settle the rears? Like sitting in the sun which we don't have this time of year here, lol!Just put them in.
Fronts are perfect.
That's a good idea.I’d take a carpentry knife and cut off a few rows of the nubs on the bottom near the door sill and see if it fits better.
I went out just a little bit ago and was trying to play with the mats a little to see if I could get them to flex down a little bit. If I take the edge of the mat and tuck it between the floor and the door sill, it sort of forms in a downward manner which results in a much cleaner look. I'm a visual guy so I'm attaching a couple of pics. Hopefully lays better after being in the heat longer.Do you think some heat will settle the rears? Like sitting in the sun which we don't have this time of year here, lol!
I've used Husky's over the Weathertechs for years and never had a fitment issue once they settled from being folded in the box. If there truly is a mating issue with the rubber floor, be sure to let them know.
Regarding the second row of the mats - has anyone driven at speed with the doors off with these mats? I think Pickens Party of 5 reviewed these and said they flop around in the second row due to wind at high speeds. Just curious before I make a purchase! I have the washout flooring and will likely shave off the nibs on the underside of the mats as well.
Bummer, albeit understandable. I wonder if something simple like 3M tape would do the trick.all rear mats will flop around with the rear doors off because there are no anchors.
Why take the rear doors off if nobody is back there?Bummer, albeit understandable. I wonder if something simple like 3M tape would do the trick.
My thought was that sometimes I've got a third passenger, so one side might sit down because of their feet, but the other might flop around. Even without the doors off, having the raised edges near the doorsill is still a little unsightly to me when the door is open. Just personal preference I suppose.Why take the rear doors off if nobody is back there?
