A10Warthog
Lee
Seattle WA
03 Cobra Terminator,Focus RS
$395 is a great price. I thought they were supposed to be over $600. By raw lumens it exceeds the DD SS3 Max which are $500. I prefer the round look over square. The covers are an added bonus too.
I'm confused, Is that for pair or $395 each?
c2one
San Antonio, Texas
2021 Ford Bronco FE
Would these work on the front bumper?
Yes, there is a wire that is pre-run to the front grill which could be used to wire the pod lights on the front bumper.
Ford's Overland build had them on the corners of the front bumper.
Ford Bronco RIGID x FORD 4" pod lights full install *** DIY VIDEO *** 1630079210118
WhiteMamba
Derek
Boring, Oregon
2021 Bronco FE, 2015 F350 2010 Focus 1995 F250
Nothing wrong with the light itself. They did a stop sale because the lights on the off-roadeo vehicles were working loose. The fix.....a line in the install instructions was added to indicate thread locker needed to be used on the mounting bolts.
I don't have the new packaging yet to see what loc-tite they are wanting. Might even be a small tube included, but don't know. This was a short conversation with my FAD rep 3 days ago.
Can you confirm pricing on these? Seems there are a couple different prices floating around.
flip
Phil
IN
www.ruxerparts.com
Fords
I can once they come in and we get invoiced. We got hosed on some of the cargo area storage units so we are pricing based on what they're billing us instead of what the price tape shows.
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
Good video @Middleton_Sasquatch
I ran my wires slightly different:
The Red line is where I ran the red wire. I removed all the clips (Yellow circles) which allowed that piece to be slightly lifted and easily tuck the wire behind.
The Blue circles is where I grounded the Black wire for each Pod - grounded separately.
The Green circle is where I spliced to two Red wires from each pod and the Violet/Green wire for Aux Switch 2 - 15w fuse.
There is also this instruction sheet as well: https://performanceparts.ford.com/download/instructionsheets/IS_M-15200K-BML_040521.PDF
I did the same on my 19' F350. After hitting some deer I opted for these inexpensive lights and OMG are the bright, cheap too @ $45 a pop.
Ford Bronco RIGID x FORD 4" pod lights full install *** DIY VIDEO *** 1630080834100
TRMFAM
Rob
OK
I noticed Rigid makes this 4" model and also a 6" model...has anyone installed the 6" version?
I assume you will not be able to use the antenna with the 6" model but for some reason in the pics the 4" look a little small...may look different in person but I am afraid the 6" may look too big. I have the LP4's on my Raptor and I believe they are 5" diameter and look huge so this 4" may be perfect in person.
Also curious why they did not connect the backlights?
BoolooBronco
James
Civic
These lights have a backlight and a drive light. I'd like to put the backlight on a separate switch when installed. I know it's possible, but I haven't seen that install on a Bronco yet. Looking forward to that so I can get mine wired up correctly.
What do people mean when they say these lights have a back light? I've seen lights with different color backlights, but it doesn't make sense to me.
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
I think it is like a show off/ DRL look. I'd like to see what it looks like running those WITH the covers.
