SPS4
Sean
Audi S4
What do people mean when they say these lights have a back light? I've seen lights with different color backlights, but it doesn't make sense to me.
It’s like a DRL or parking light. The amber looks pretty slick IMO. Gives visibility without being obnoxious.
Advertisement
Khayze427
Hayes
Valley Forge, PA
Jeep JKU
We just installed the RIGID 360 series 4 inch pod lights from Ford.
Why did you use the 25 Amp circuit? Shouldn’t that be reserved for something that requires more current than the pod lights? I believe the Rigid 360 4” pod lights draw only 2 amps.
Khayze427
Hayes
Valley Forge, PA
Jeep JKU
Nothing wrong with the light itself. They did a stop sale because the lights on the off-roadeo vehicles were working loose. The fix.....a line in the install instructions was added to indicate thread locker needed to be used on the mounting bolts.
I don't have the new packaging yet to see what loc-tite they are wanting. Might even be a small tube included, but don't know. This was a short conversation with my FAD rep 3 days ago.
Do they come with security bolts? Otherwise, gone in 60 seconds. With, gone in 75 seconds.
flip
Phil
IN
Fords
No idea, only cracked one box open to get an idea how to mount to my display.
VictoryLights
Pittsburgh
2018 Honda Pilot
Where can I buy these? Do they come with the ford performance covers?
TRMFAM
Rob
OK
Rigid site
checkout the rigid site. You can get them with a lot of different backlight colors. I assume the ones from Ford are amber backlit but I have not seen that stated anywhere. The backlights are not really daylight viewable but look great in the evening or other less than full sunlight conditions.Absolutely zero real world value but looks awesome! I have rigids in my Raptor bumper and Baja designs lp4 on the a pillar and all have amber backlights and I wired them all to one up fitter switch. The actual bright white off road lights are wired to separate switches per light pair.
rigid also sells clear, amber and smoke covers. I thought I would get the smoke and have my wife create the Bronco eb script stickers with her Criket to put on them. Just a thought. The radiance light bar also has backlit functions but it has 7-8 colors all in the light and you can change it with a remote. I wish the pods were the same.
4avor8ntfair
Houston, TX
Explorer
On Rigid’s website, they’re $367.99 for a pair. I’m not sure what, if anything, the Ford set comes with for the extra $30.
I’m not sold on Rigid yet, vs Diode Dynamics vs Baja.
nwGTS
Nate
Chicago, IL
Porsche 911 GTS, BMW E46 M3, Honda CRV
wait wait wait. it took him 9 minutes 25 seconds to install these and the standard dealer install labor hours charge is two hours?!? Something is afoot.
mC.242
2021 Bronco Big Bend, 2006 Pathfinder, 2015 Mazda6
Good video, although the actual routing of the driver side wiring down into the engine compartment was kind of skipped over. Probably easy enough to figure out, though.
Related topic: Anyone know if the wiring is in place from the cabin to under the hood if you didn't order the switches from the factory and want to add them later?
It is on my BB without the aux switch package 👍
TRMFAM
Rob
OK
@FATHORSE thanks for posting...add for step 2 to apply locktite or similar compound. Personally I rarely use Locktite anymore and have switched over to vibratite and have better luck with it. It is more of a go to in the firearms world and I began using it on other applications and have had better luck. Our front storm door has a lever handle with a set screw and I locktited that screw with blue first then when it came out I went to red and it came out again. One application with vibra-tite and has been on since (2+ years). Plus each application is good for several removals / reinstalls without the need to re-apply. One caveat you will have to use channel locks to get the lid off the bottle and I swear it does not matter how careful you are or how clean you keep the lid / jar threads! But it comes right off every time...YMMV!
Vibra-Tite
Question is there a page 5 to the install? Surprised the instructions didn't show connecting to the upfitter switches...also interesting they detail not running the passenger light ground wire across to the drivers side but instead to ground on each side individually. I guess that would save a few feet of wire.
FATHORSE
Stephen
okc
nissan
Vibra-Tite
Sorry, Fixed it, btw these are on that ford performance site in pdf. Just figured people that didnt dig into it would want to see it.
Advertisement
Holley (Ford Fest banner)
Advertisement
