Rock rails usable as jack hardpoint?
Zinn
Minnesota
2016 Mustang GT, 2020 Ranger Lariat
One of the first mods I did on my Mustang was adding some underbody rails that bolted over the jacking hardpoints. These have been super helpful because I can jack one whole side of the car up at once to swap wheels, instead of having to do it four times on four different hardpoints.
I'm wondering if the OEM rock rails on the Bronco will be usable in the same way? Or would jacking from the rock rails damage the body of the vehicle?
Advertisement
bbqbronco
Houston, TX
18 Mustang GT
Hm it's probably not the best idea since they're body mounted. They're meant for protection and turning the vehicle in tight spots. I'd be happy to be wrong though.
McCracken
Northern Michigan
2012 Ford F-150 FX4
They say the are mounted to the structure of the body, and can take the weight of the vehicle (rumor), but I've never used the body of a vehicle for a jack point, and I would not advise using the rail as a jack point either. It would be like using a running board...
Use the frame, less risk of damage.
damarble
Spokane
01 Sport Trac
It's very common to do that with aftermarket rock rails. If Ford actually patterned them after what people really use, then we should be able to.
kodiakisland
Arkansas
2012 Tacoma, 2016 Camaro, 2018 Indian
They are mounted to the body. Use at your own discretion. I wouldn't.
N3T
Ed
Detroit
95 e320 wagon
I’m hoping the frame will be stiff enough that when you raise the rear wheel the front wheel comes with it. Had a bunch of German cars like that & made life simpler.
MrJoe
Joe
Southern Maryland
'73 Bronco, '99 Ram, '08 Explorer, '16 CMax
They did say the rock rails were designed to handle the weight of the vehicle. I wouldn't hesitate to try it, in a pinch.
Ramble_Offroad
Nels
Lyons
2012 DCSB TRD Tacoma
Hmmm... if they can’t be used for a highlift that’s one more reason to swap them for proper sliders. I’ll be watching the aftermarket closely on this.
We should add this to the next super whatever east coast event. How does that work? Anybody going to the next event?
Economisto
Matt
Houston
www.semiramisusa.com
2000 Mistubishi Montero, 2013 Audi S5
Pretty sure someone said you could rotate the whole vehicle from one pivot point of the rock rail without issues. I would wait to see it done first by real users before you try to use it as a jack.
Advertisement
Advertisement
