For those that have truly used rock sliders to bang around on, do you think Ford connecting their rock sliders partially to the pinch welds is acceptable?
That makes me nervous about the GOAT fab option then. They haven’t been real clear yet on their plans, but recent post from them seem to indicate they will be doing both attaching to body and frameIf the sliders are mounted to the body, the additional mounting to the pinch weld should be ok.
Now if you are frame mounting them, they can't be attached to the body since the body and frame flex.
I actually saw that same post after I had responded to this one. We'll see what they say. I could be wrong with my understanding, but if they wanted the two to be tied together, they wouldn't have put rubber in between the body and the frame.That makes me nervous about the GOAT fab option then. They haven’t been real clear yet on their plans, but recent post from them seem to indicate they will be doing both attaching to body and frame
I'm with you, partially. I think people that look down on body mount rails versus frame rails are not taking a lot of factors in the consideration. For example anyone that isn't trying to climb over boulders the size of your vehicleAfter watching LiteBrite vid of Kevin landing on his factory rock rails, the wheeling I'll be doing, the factory pinch/body mounted rails will work for me. I know he has since changed his out to beefier ones, but still mounted with pinch/body mounts. Time will tell as he wheels their Bronco more, how this mounting will hold up. He's not shy on where he puts his vehicle so I feel he'll have the best perspective on this setup.
I can agree with that. The first set of rails/sliders that Kevin was prototyping, he said the same thing about the coverage for the doors. Next Venture Motorsports went back and modified them and second set has the coverage for the doors. If I see the need, the NVM sliders will be the ones I go with. Nice product.However what's not really debatable, is the fact that factory rock rails don't really protect the sides. Especially on the Bronco because it sticks out wider.
For me, Rock rails are for the sides/lower panels and skid plates are for the bottom.
Yes.I would like a show of hands as to those who have actually drug, scraped, pivoted your rockers on a rock. ...
I would like a show of hands as to those who have actually drug, scraped, pivoted your rockers on a rock. I have done moderately severe four wheeling most of my long life and have done that only with a belly dragging Jeep Commando or a long wheelbase pick up with hangy down step rails. Unless you are doing serious rock crawling (fewer than 1% I would bet) it's kina academic. I got the Ford rails, they are rated for the vehicle weight but more importantly cover the pinch weld and protect the lower rocker from an errant stick, log or rock that pops up unexpectantly.
