- Banned
- #46
Hopefully the top plate would be an option as I personally love these, but wouldn't be a buyer with a fixed top plate.
My wife wears heals often and has preferred having the bar vs a top plate as the top plate snags heal when getting out. LOLYeah, this ^^^^. Also, I don’t want my wife’s feet tangled up! Maybe make non-skid top plates an option. Wouldn’t have to be entire length. Perhaps just 4 in the vicinity of the doors.
Does the leading edge of the slider protrude a little into the front wheel well? I’m asking this to figure out whether a mud flap will fit there without having to cut a hole in the mud flap to accommodate the leading edge of the slider.
Otherwise, congrats on a really nice design.
Edit: you just answered my mud flap question upthread, thanks!
We will have a seperate version out shortly after this version that will work with the factory rails.It looks like you could leave the factory badlands/Black Diamond rails on with these too...like you can with Wrangler factory sliders to cover the holes in the body. Is that correct?
Looks great...hopefully priced competitively and able to install without drilling.Finally a true rock slider for the new Bronco. 2" x .134 wall steel tubing. Will be finished in primer and textured black powder coat. Attaches to rigid sub-frame not just a pinch seam mount. 12 bolted locations per side. GOAT Fabrication rock sliders will be available soon with our lifetime warranty!!!
4 door crew four life!If you have a 2 door, they should be affordable as they will be half the price of the 4 door. Right @GoatFab?
*should've4 door crew four life!
I see weldNo, These are bolt on.
Haha, I always said Ford should have made the 6G Bronco a 2 door like the original and if they ever make one, I'll buy it instantly.4 door crew four life!
I honestly I have zero issues with either. Different strokes for different folksHaha,
That may be the other set another poster posted for comparison.I see weld
