Roof Cargo Box for 2022 Bronco?
Wareagle1413
Savannah, Ga
2022 Bronco
Are there any specific types of cargo boxes that need to be used for a ‘22 Bronco or are they all adaptable?
Biltwild
New York
2014 Nissan Titan Pro-4x , 2021 Ford Bronco 4Dr BD
Thule XXL on the RCI roof rack. Has a big range of where you can have the cross members.
Ford Bronco Roof Cargo Box for 2022 Bronco? 4BC6A347-BF0D-4773-8E10-0C0CF08E108B
Wareagle1413
Wareagle1413
Savannah, Ga
2022 Bronco
The Thule Force XT XL fits okay on the oem rack. It would fit better if you could adjust the oem bar spacing.
The cross bars are adjustable. They give you the tools to do so when you purchase the vehicle. You just have to loosen the star bit screws and move it to where you need it to be.
Jtv107
Josh
Charlotte, NC
‘22 Bronco Wildtrak
I only see two possible locations for the crossbars, front and middle. I do not see any further adjustability for the OEM rack.
mikes781
Nj
2016 F150 Lariat
@Biltwild I just ordered a bronco and am looking at roof rack options and would really like to add a cargo box. One thing that I’m noticing with most cargo boxes is that they aren’t flat on the bottom. With a rack like this that has a flat mounting surface and no load bars, did you run into misuses mounting the box to the rack? I assume that your box has the clamp style mounts. Does the curved part of the box just fall between the bars? Thanks
