- First Name
- Mitch
- Joined
- Mar 11, 2021
- Threads
- 26
- Messages
- 2,309
- Reaction score
- 4,013
- Location
- Cape Cod, MA, formerly Flagstaff, AZ
- Vehicle(s)
- 2021 2 Door Badlands manual, 2021 Tacoma TRD OR
- Your Bronco Model
- Badlands
2535# per tire x 4 = 10140# total load capacity, the tires are not the limiting factor in this equation on a vehicle that weighs 5320# max. Ford uses the same C spec tires on 5750# Raptors with a cargo capacity of 1400# and tow capacity of 8200#, no problems with weight there.We've all seen multiple posts and discussion on the inability to put a roof rack on a Sasquatch package . They're pretty clear that it has to do with weight capacity , but it may mostly be the tires!?
So, if you look at pg. 12 of the Bronco Equipment Installation Guide, released on Bronco Nation Today, theres a table on Roof Rack Load Capacity:
In motion: 110lbs
Stationary: 450lb
315/70R17 tires: 0
An Explanation: If you look at the specs on those Goodyear Territory tires, you'll see that they are the softer "C" rated tires, with weight capacity of a measly 2535 pounds! Thats weak for a loaded vehicle, same as the stock OBX tires. But that explains the capacity issue, ITS THE TIRES! A fix would be to upgrade to an E rated tire, get a rack, and move on. Im guessing that the suspension components are pretty beefy, the tires seem like the weak link in the design chain. E rated tires are heavier, and a harsher ride.
Clearly Ford wants its Sasquatch to be comfortable, and this may be part of the design compromises on a vehicle with 35" tires (actually, Theyre 34.4" tires) extra machinery, armor plating, and soft tires . . . When theres the extra weight of 4 doors, 2.7 engine, auto trans
Any thoughts?
I wouldn’t want harder riding E rated tires capable of holding 12800# on a vehicle as light as a new Bronco. My 5500# 87 Bronco rode like crap on D rated tires, it was just right when I went back to 315/70R17 BFG’s that were C rated. I am very pleased that Ford specked C rated tires. For years most of the larger tires in 17” have only been available in E rated, the same is still true in 18 and 20”, they ride like crap on lighter vehicles.
Bronco weights:
Raptor specs:
