I do a lot of woodworking, and I will need the roof rails and crossbars for hauling a little lumber very now and then. I can probably fit some 12' material up there if I tie it down right.
You can ask the dealer not to installYes, but I will probably have to remove them on my Basesquatch when I get home from the dealer to be able to park in my garage.
The canoe looks awesome on the base bronco for the retro look, especially when you use those front tie downs.Aka surf rack, a must have for me.
Assuming the preliminary specs are still all true, even a Sasquatch with a roof rack only comes in at 78.9". That should fit through any standard 7' garage door.Yes, but I will probably have to remove them on my Basesquatch when I get home from the dealer to be able to park in my garage.
I have some weird 1960’s built garage and it’s going to barely fit the Sasquatch with the specs from Ford.Assuming the preliminary specs are still all true, even a Sasquatch with a roof rack only comes in at 78.9". That should fit through any standard 7' garage door.
Same here. But since I'm planning on a 2-door, I'm hoping for a aftermarket solution that uses the front fender tie downs to provide an extended rack over the front end. ...For those times I need to haul 12' board or an extension ladder.I do a lot of woodworking, and I will need the roof rails and crossbars for hauling a little lumber very now and then. I can probably fit some 12' material up there if I tie it down right.
That's a good idea! Before I go that route, I'm going to try just tie down strapping all the lumber together with the outer pieces on edge for rigidity and then tie down to the front fender tie downs too.Same here. But since I'm planning on a 2-door, I'm hoping for a aftermarket solution that uses the front fender tie downs to provide an extended rack over the front end. ...For those times I need to haul 12' board or an extension ladder.
I've already suggested this a few times here, but here goes again...
Ideally, I picture the roof rails having an inner rail that slides out when needed, while an outer rail remains fixed on the existing vehicle mounting points. The front crossbar would actually be a double cross bar comprised of a fixed crossbar connected to the fixed outer rail and a moveable bar connected to the inner rails.
The moveable cross bar could be hollow underneath such that the vertical tie down bars pivot and tuck up inside when not needed. With the inner rails extended and the front crossbar over the hood, the tie down bars are released and pivot down (one left, on right) towards the front fender tie down points where they are then locked in place.
And voila... a three cross bar system spanning the length of the vehicle.
Any aftermarket companies out there... this one is free, just let me know when you have one ready for me to field test.
I have to say, 450
Thanks for posting! 110# is pretty pathetic but will hold my two kayaks just fine.
Correct.By "Dynamic" I assume that means when the vehicle is in motion such as when driving with cargo on the racks, while "Static" means when the vehicle is parked such as when using the tent on the roof.
