I tried the craft foam solution at the locating pin which worked well. I have also contacted my dealer to see it they have a more permanent solution.Same at 1000 miles. Noise gets worse everyday
its going on city roads, highway, over bumps etc. took it to my deler and they added these little foam pads that have made it stop rattling but seems as though its been fixed.
I have this problem the passenger A pillar top or something rattling and squeaking. After removing the top and lubing the seals I got the problem to go away for about 250 miles but now it is back and will not go away. This top is an issue.I have the 2.0 and have noticed a few issues that sound familiar to others. Built 9/28.
1) It sounds like something is loose in the drivers A pillar but after repositioning the driver roof section it goes away for awhile.
2) When leaving the Off Rodeo in Vegas there is a section of dirt road that is wash boarded. My top was making a loud squeaking/rattling noise from the passenger rear area while I was driving on it. (It didn't do it on the way in for some reason) Now I notice it whenever I hit a bump.
3) The edges of the rear section are not finished in my opinion. You can see fiberglass hairs and the laminations which in one area they are slightly separated.
I was hoping that getting a 2.0 that these problems were addressed.
At 2200 miles on it, even with these issues I am very satisfied and grateful to have one. Hopefully @Ford will come up with a quality top that solves all the issues we are having and replace them.
Edit: #2 is definitely temperature related. On my drive home on the same road it was noisy in the morning and much quieter in the afternoon.
What is the delrin alignment stud? Any particular type of silicone spray?My MIC 2.0 had this issue too, I simply wiped some silicone spray on the delrin alignment stud and haven't heard the popping since.
Had the same thing happen with my Wrangler's roof.
It's a 1" plastic post coming off the hardtop panel, it fits into a hole in the rollbar to line up the panel when your putting the top back on.What is the delrin alignment stud? Any particular type of silicone spray?
600 miles and not rattle but the wind noise is more than I expected...livable for what it is but more than expected vs the hard top Jeeps I have been in.
My Jeep top is great! Maybe my wife having to wait 12 years for this Bronco won’t be so bad after all.Same at 1000 miles. Noise gets worse everyday
basically right where the the rear of the drivers side meets the front of the rear piece above the drivers headWhere did they add the pads to? I am going to contact my dealer to see if they can do the same thing. Thank You!
I had the same thing, then I took it on some trails and it stopped doing it.600 Miles and i now have a rattle coming from above front passenger head.
https://www.bronco6g.com/forum/threads/quick-psa-squeaky-popping-mic-fix.28831/What is the delrin alignment stud? Any particular type of silicone spray?
