- Sam
- Jul 2, 2020
- 65
- 844
- 3,769
- Detroit Area
- sas
- Black Diamond
The price Ford performance is asking for their mirror lights I think is BS, so I went searching for options. I wanted something that would mount up very similar to how the Ridgid mirror lights mount. These did the trick.
They mounted perfectly with the bronco bolts with zero issue. These are NOT made specific for the bronco, so they come with a massive wire harness that is completely unnecessary. I had to cut a lot of pieces off and do quite a bit of wire splicing in order to make these work, however it didn’t take too long and I was able to thread the wires to their proper spots. I essentially followed the instruction manual from fordperformance.com for the rigid mirror lights.
I think these look better personally, simply due to their size. The brightness is pretty good, probably not as good as the rigid however.
These puppies only cost $80
