Rough labor cost / price estimate on 2-inch lift install?
desibull
Mahesh
Chandler, AZ
BMW 335i
I have decided on NOT Squatching my BD but would like to raise the body up a couple of inches...what is the rough cost for doing so?
wvmtneer
ā€˜Merica
F-150
I donā€™t think body lifts have been used since the 90s.
Gr8Hortoni
Whitehall, Michigan
Jeep Wrangler, Ram Rebel. Previously 2 wranglers and 4 Broncos
Hard to tell initially. Would recommend checking leveling kits first if all youā€™re looking to do is squeeze a little bigger tire in there. Jeep level kits run from as cheap as $30 to $4-500, depending on size. Full lifts wonā€™t be cheap due to the ifs.
Gr8Hortoni
Whitehall, Michigan
Not as prevalent but still out there. Just helped my buddy put an extra 1 1/4ā€ on his JL Rubi to help clear 40s with 4 in suspension lift.
attworth
Tony
2000 Land Rover D2
Youā€™re going to have literally hundreds of options once the market catches up.
Ranger lift - this is a pretty decent kit for the ranger for $1200. The Bronco will be similar sized, but has coil overs front and rear, where the ranger is a leaf sprung rear. I would estimate $1800-2000 for a Bronco kit similar to this.
Incognito
Phoenix
2017 jk
Body lifts are used on JK jeeps going to 37" tires.
The tires are getting so big in that size, that the inner top of the tread wants to hit the sides of the body tub at full flex.
Completely removing the fenders doesn't help with that.
I'm thinking of going with a very simple and subtle 1" body lift on my Basesquatch.
That will let me get rid of the SQ's extendedbump stops, and make room for true 35" tires.
The GY Territorys ( and all 315/70R17 tires) are actually 34.5".
vrtical
Doug
GSMNP, TN
Fords
2" leveling kits for Bilstein's / Fox applications already exist for the coilovers
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
It might not cost anything but a little of your labor. On the Gen-1 Raptors the Fox shocks were height adjustable. It didn't take long for someone to discover that little hidden gem. They came from the factory set at the lowest height. They have two additions positions to raise the height. Quite possible that the Bronco suspension may have the same. Until the Bronco is in customer's hands we won't know.
