Roush Performance 2.3L Bronco R Series Cold Air Intake Installation
LethalPerformance
South Florida
www.lethalperformance.com
A couple of weeks ago you got to hear the Roush Performance exhaust on our 2021 Ford Bronco First Edition and now we're BACK with more Roush goodness! Jared installs their new R Series Intake for the Bronco. This thing is CLEAN and will definitely help get more airflow in and keep the dirt out (especially when paired with the supplied pre-filter... which is NOT a hair net...) The intake fits both the 2.3L and the 2.7L (not BUT the Sport, sorry).
2021 Bronco R Series Intake Features:
High-capacity air filtration system
See-through window Enhanced turbo sounds
Pre-filter included with "R" logo
Fits both 2.3L and 2.7L
NO tune required
The 2021 Bronco R Series Intake Features a Larger Capacity Air Filtration System The 2021 Bronco R Series Intake is the result of ROUSH taking a deep dive into the off-road capabilities of the 2021 Ford Bronco. This intake gives the air filtration system in the vehicle a larger capacity and prevents dirty, toxic air from getting into the engine. It is specifically designed with the off-road enthusiast in mind by protecting your engine for better performance when riding out on the rocks and trails. You do not have to worry about doing anything special to check the dirt buildup in the airbox because this intake comes with a clear monitoring window so you can easy monitor the filter throughout your day of off-road adventure.
This is the perfect intake to protect your engine health no matter where you choose to take it. Perfectly Combines a ROUSH Pre-Filter System with a Larger Capacity Filter The 2021 Bronco R Series Intake puts together the technology of a ROUSH pre-filter system with a large capacity filter. This means better air filtration that and better engine health over time. It is easy to keep the filter clean when it starts to build up dirt because the it is washable and reusable. Never stress about ordering new filters when you can just clean the one you have. You will always know when it is time to clean the filter because you can check the convenient clear monitoring window. This intake system is compatible with both the 2.3 L and 2.7L powertrain of the 2021 Ford Bronco.
cwbolyard
What effect has it had on fuel economy?
LethalPerformance
LethalPerformance
South Florida
I haven't really checked as my wife drove the Bronco this weekend. I can tell you that the fuel economy from the Whipple cal has been amazing. Not so sure I'll be able to notice any difference after adding the Roush intake but I'll be glad to take a look. On the turnpike last week going 74mph with cruise control on I saw 21.4mpg. That's the best I've seen on it so far. Will report back after some more testing this week.
Thanks!
Packman
Honolulu
2011 Ford Mustang Pace Car
Does it fit in the same footprint as the current air filter? I just installed the ARB air compressor on the 4x4 LED mount. Do you think that could interfere with the placement of the Roush filter or would I be good to go?
Ford Bronco Roush Performance 2.3L Bronco R Series Cold Air Intake Installation 5AF82226-32F1-401C-8091-AAAC83C2B776
LethalPerformance
LethalPerformance
South Florida
Does is fit in the same footprint as the current air filter? I just installed the ARB air compressor on the 4x4 LED mount. Do you think that could interfere with the placement of the Roush filter or would I be good to go?
There won't be any interference with the ARB air compressor. The Roush lid is just a tad taller than the factory one where the window is above the filter. Based on the location of your air compressor in the image it looks like you're good to go.
Let us know if you have any other questions in the meantime!
LethalPerformance
LethalPerformance
South Florida
Still have these in stock?
Indeed we do. We can get one out the door for you today no problem. Give us a call if you have any other questions or need help placing an order.
Thanks!
RainbowStix
A Big Island
Toyota Tacoma
Thanks!
Any update on this?
