Routing Power for Ham Radio
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
Big photo dump here. I wanted to put the radio itself in the cargo compartment, especially considering there is so little space in the passenger compartment. My plan is, once I get longer control and mic cables, to put the faceplate on the accessory spot and put the mic on the dash. So, down to photos and the massacree (went pretty well, actually).
Ford put in a grommet to run cables through the firewall - I punched a hole in it and ran the cable through the hole:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_be8
Then I routed it behind the trim panel and into this nifty little wiring tray under the trim - the trim just pops right off, so it's super easy:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bea
Ford Bronco Routing Power for Ham Radio XRcb4NYSR%ScGmE9aDjXrw_thumb_bec
Same for the back seats (you 2 door people, no idea how that will work):
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_be7
Fished the cable up into the cargo bay:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_be6
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_beb
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_be9
Then put all the trim back together:
Ford Bronco Routing Power for Ham Radio bBDTMi4aTMeujGBA1eVvGg_thumb_bed
Ford's provided accessory posts on the battery terminal. M6-1.0 nuts fit. The Bronco toolkit that comes with the Bronco has a socket that will fit, so you don't even need to open your toolbox.
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bee
I pretty much use Anderson Power Poles on everything:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf2
Watertight through hull for marine applications - I drilled a hole through the trim and installed the through hull:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf5
Connected the through hull to the cable going to the engine bay and clipped it so it won't come apart.
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf3
Installed:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf4
ChrisD
ChrisD
Next was cabling to the battery - my battery cable is fused on both positive and negative and I connect to the main wire I ran earlier and clip it so it won't come apart:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bef
Got power:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf6
I use a Rigrunner so ran a jumper from the Rigrunner to the power outlet installed earlier. Now, I have lots of places to plug things in:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf7
I want to put the radio on the opposite side of the truck as the power outlet. It's mostly because I ran out of room... You can remove the floor in the back of the Bronco using a 10mm socket and once you do that, you can lift out the trim behind the back seats. That gives you a place to route the wire across the cargo compartment under the floor:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bfc
I used a fish to pull the wire up behind the trim. I'm too lazy to remove all the trim:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bfb
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bf9
Zip tied the power cables to the wiring harness that runs behind the back seats:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bfd
Put the trim that goes behind the back seats back on:
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bfe
Reinstalled the cargo floor (yes, my pull tab for it is broken due to an unrelated incident):
Ford Bronco Routing Power for Ham Radio UNADJUSTEDNONRAW_thumb_bff
I'll have to do the rest with the radio later - I have control and mic cables on order, so once those arrive, I can finish the install. For now, the radio is working, it just still looks ugly!
ChrisD
ChrisD
The through hull is a nice touch and a great idea. If someone didn't know better, it looks like a factory port.
Thanks! I wasn't sure how it would turn out, but I'm pretty pleased with it. I'm thinking about getting a couple more to clean up the cabling.
I actually like this vehicle so I'm trying to do as good a job as I can. I'm not 100% satisfied with everything yet, but it gives me a hobby.
Scumby
Ron
95 bronco
What radio and Antenna are you installing?
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
Looks great Chris, I will be doing something similar and will use your routing when I install my FTM400! Thanks for documenting.
Krazed
Kirkland, WA
An e-bike
How are you installing the antenna?
ChrisD
ChrisD
Yaesu FTM-400. I pulled it out of my old pickup when I sold it and reutilized most of the stuff I already had out of the pickup. It has the integrated GPS and APRS, so I like it in the event of a problem, I can ping out and people can find me on google maps. :)
As far as the antenna, I'm using one that was in my garage for now, just a tailgate lip antenna mount. I had to mess around with the mount some since the tailgate on the Bronco swings inward on the mount side. I didn't want it banging into stuff if I opened the door all the way.
For now, I have the radio working, but it's just sort of velcro'ed in place and the wiring is all wonky since I need longer control cables.
ChrisD
ChrisD
I'm not sure what the permanent situation will be, but for now, I am working with this a trunk lip mount. I'm leaning toward running the feedline through one of the grommets under the floor, then following the frame to the front and mounting to the hood for long-term.
I have a trip next week and I was tired of using a HT for mobile comms.
Also, I'm going to have to remove this when it goes into the body shop to fix the transit damage, so wanted something temporary.
Ford Bronco Routing Power for Ham Radio IMG_2034
Krazed
Kirkland, WA
An e-bike
That doesn’t look bad. Have you thought of the trail sight attachment points on the hood?
ChrisD
ChrisD
Haha, I wanted to be able to talk with you without trying to relearn how to operate my HT! :)
ChrisD
ChrisD
I have, actually! I suspect someone will come up with a professional mount that goes there in time. It'll take some fabrication to get to, though...
There's not a lot of clearance between the inside of the trail sight and the hood when the hood is raised. Most of the luggage rack or mirror mounts that exist would prevent me opening the hood...
Something that hinges on the bottom, then screws in at the top on the outboard side with an NMO or UHF slot that would accept an antenna base would probably work. I'm not sure if I want the antenna that far out forward, though...
I'm really still thinking about it...
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
The only advice I can say is to add a drip loop with any wire that you feed through the firewall. If it gets wet under the hood, it will drip before going into your cabin.
I'll be moving mine from the Taco to the Bronco when I actually get said Bronco....
ChrisD
ChrisD
That's a really good idea. I was going to seal up the cut I put in the grommet with silicon since I'm not routing anything further through it, but that's a great idea!
