RTR Rock Sliders for your BRaptor!
RTR Vehicles
Lux Sponsor (Level 2)
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
The RTR Rock Sliders are available for BRaptor! Our Rock Sliders are constructed from 1.75-inch DOM (Drawn Over Mandrel) steel tubing. Utilizing DOM steel tubing has several benefits such as the highest weld strength, uniform wall thickness, and leaves the finished product with a smooth and clean surface. Each Rock Slider is finished in a 2-stage powder coat for corrosion resistance and texture for increased grip when using them as a step. The Rock Sliders give you 4-inches of surface area to be used as a step or lifting point. They also feature a 7-inch rear tire kick-out that was designed to protect the body of your Bronco when going over larger obstacles out on the trails, this kick-out can also be used as a step.
Ford Bronco RTR Rock Sliders for your BRaptor! IMG_7158
The RTR Rock Sliders sit higher and tighter to the frame of the BRaptors chassis. Heavy duty steel mounts are used to secure each Rock Slider to the OE mounting points. You will gain up to 1.5 inches of additional clearance by removing the factory BRaptor side steps. A pair of 4-door RTR Rock Sliders weigh 110lbs. When mounting these some slight modification is required. The front fender flap needs to be removed to clear the RTR Rock sliders and the inside fender wells need to slightly cut.
Ford Bronco RTR Rock Sliders for your BRaptor! IMG_7168
Ford Bronco RTR Rock Sliders for your BRaptor! IMG_7177
Ford Bronco RTR Rock Sliders for your BRaptor! IMG_7148
To learn more about the RTR Rock Sliders for your Ford BRaptor, please visit the LINK.
ORbronco
Jeremy
Oregon
75 Bronco, 22 Braptor
Ordered mine last week. Can’t wait to get them on. I like how they come farther than some others. It allows you to pivot off of a tree if needed.
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
Can you post an up close pic of the fender cut
RTR Vehicles
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
We notched the bottom of the inner fender liner. Nothing major at all and we removed the additional fender guard since these are much tighter to the BRaptor body. You could potentially notch those if you wanted to retain them.
Ford Bronco RTR Rock Sliders for your BRaptor! IMG_3851
Ford Bronco RTR Rock Sliders for your BRaptor! IMG_3852
ORbronco
Jeremy
Oregon
Looking at your tire carrier. Will that fit a Braptor?
RTR Vehicles
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
That is still on our list of components to upfit on our BRaptor. As soon as we test fitment, we will make sure to share with everyone!
