Very nice photos, is this Zion? Rim trail area?If you have an RV and are planning on pulling your Bronco..Where are you top places?
1. Utah (So many places)
2. Colorado
3. Arizona
2. Colorado
3. Arizona
yes. Zion. Great place!Very nice photos, is this Zion? Rim trail area?
This rating is not for the towing vehicle but is the hitch capacity. You still need to stay within the tow vehicles weight restrictions, and to do that properly you need to load the RV for a trip and then get it weighed at a scale, front,rear, and combined weight, then subtract that from the GCWR from the data plate next to the drivers seat or it may be on the entry door. The difference is the allowable max weight of the towed vehicle.Here is a good example of what you need to know before you tow a car with your RV.
https://www.thefitrv.com/rv-tips/how-much-can-you-tow-with-a-small-motorhome/
The one that comes with the BD or BL. heavy duty..Anyone have a guess on which bumper would be best for flat towing? Looks like 3 different ones.
Did you see the "capable" bumper in B&P? I'm not sure what the differences are with it?The one that comes with the BD or BL. heavy duty..
No. I will check it out. The last thing we want is to leave are Bronco on the road.. lol Thanks!Did you see the "capable" bumper in B&P? I'm not sure what the differences are with it?
I'm currently using the Blue Ox Alpha. I like it.RV Tow Bar system question: Does anyone have any suggestion of a very good Quick Release RV TOW Bar for Flat tow? Thanks!
You can't go wrong with BlueOx, have been using them for many years. Currently have an 'Alpha' bar, very easy to hook and unhook, about 2 minutes, stores on the back of the RV and pivots and swivels as well as auto lock telescoping arms to allow off level hookups, weighs in at 40# and is rated at 6500# tow capacity.RV Tow Bar system question: Does anyone have any suggestion of a very good Quick Release RV TOW Bar for Flat tow? Thanks!
Hmmm, the only item I have seen for towing is the tow package for the back of the Bronco for $595, I show nothing under Bumper Accessories.Did you see the "capable" bumper in B&P? I'm not sure what the differences are with it?
Go into OBX.. They list a "Capable" bumper for adding accessories like winches, bull bars and lights. Looks different...Hmmm, the only item I have seen for towing is the tow package for the back of the Bronco for $595, I show nothing under Bumper Accessories.
So, a little different design to accommodate the fog lights, but the same. You do not tow with the bumper, not a 5K vehicle, you use the Frame rail tow points, same on both bumpers. This is basically so you can put a winch on it.Go into OBX.. They list a "Capable" bumper for adding accessories like winches, bull bars and lights. Looks different...
