rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
604Bronco
British Columbia
www.bronco6g.com
Cased
middle
dune buggy
Good to see Bronco getting the proper use ......
Doing fun stuff
By the way how the heck do you keep from sucking up debris out in the ocean.
Mine see's a wood chip on the lake and bam , it's in the pump
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
Sand goat. I had to look that up. Never heard of one before.
Ford Bronco Sand Goat Mode in water is impressive! goat-5041453_1280
buzpro
Binky
Tacoma
exactly the task I will be doing over and over, thank you. Now I just need a trailer hitch.
I need a trailer hitch too ..... plus a trailer .... a boat ,,,, and a lake ..... then I will be all set!
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
I need a 3-4" drop ball as we had to open the tailgate/door of the bronco to get under the Spare Tire and latch the Tongue!.
the real thing to check was whether the trailer was flat while attached to the rear of the vehicle.. hitch your trailer and get a level and put it on the draw bar of the trailer, your ultimate goal is to have the trailer as close to level as possible when fully loaded. as far as the drop being tucked under the spare tire, consider that one more security feature of the trailer when you are parked at the launch..
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Nicely done. I hope the brackish water doesn't do a rust job on her. Do you plan on using the bronco often to launch into brackish or salt water?
regularbronco
regularbronco
Shawn
F150 Platinum
Make sure you power wash the underside of your truck now.
Hose it down while cooling myself off in the Niceville/Destin Heatwave. Goggles on and hose on full! Felt great and got incredibly detailed look at the Mechanicals of the Badlands underside!
regularbronco
regularbronco
Shawn
F150 Platinum
Yes, will modify PWC trailer with longer tongue and tilt.
It's aluminum, and 10 years old like the Wave runners, but everything gets a Thorough fresh water wash down, including Skis engine Flush EVERY TIME they go in the water.
Skis engines get 656 sprayed on them as well for corrosion prevention!
  • Like
Reactions: Dom
waveform55
Brad
TUCSON
2012 F-150
Dude is that Lilian highway in Pensacola? I used to live right off dog track! Far out!
josedirte
joe
2020 3500 Ram Limited, 2017 Titan XD
7/31/21. UPDATE Photos
So Waverunner sucked up Rope, had to emergency extract away from the launch.
Bronco went 4low and Sand Goat Mode in Brackish water for extraction
Bronco Badlands, stock tires went where I would have never put our F150. We had a second Bronco at the ready, but so impressed with the controlled extraction very limited wheel spin with factory psi in tires.
worry about the Brackish, how ya gonna flush?
