Sasquatch gearing at highway speed?
elseminoleguapo
Javier
Miami
Basesquatch
I've never owned a car with tires in the 32"+ realm and 4.46 or 4.7 final drive. Leaning toward a BaseSquatch possibly with the V6 right now.
The gearing sounds good for acceleration and off road, but I'm wondering if it will make highway speed limited. I imagine the 10th gear in the auto must be pretty tall to combat this, might be more of an issue with the manual. I daily drive around Miami with highway speeds often 80-85 MPH. Is the sasquatch going to struggle or be at a really high RPM at speeds over 80 mph?
NCOBX
H2 Hummer, Holden Commodore
When you go to taller tires you need steeper gears to compensate. As long as you keep them in sync then the RPM will more or less be the same as a 3.73 geared truck with 31”s.
My H2 on 37s with 4.56 gearing and only 4 speeds cruises along at 80-90MPH without a hiccup.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
The top two gears in both the MT and AT are quite good for interstate driving. High RPMs will not be a problem. For most of my driving I doubt I even use 6th in the MT.
Ford Bronco Sasquatch gearing at highway speed? 1600885261242
ColoradoGuy
* looks at Wildtrak trim* I trust they have this well covered. ;)
20Bronco21
Amidst the Cornfields of Illinois
’22 Badlands, ‘23 Balands
Here is the equation for figuring rpm at a set mph. This is making the assumption that you are in the highest gear of the transmission. If you plan on the manual transmission, your overdrive factor is 0.646. Sasquatch tires are 34.5”.
MPH x Axle Ratio x Overdrive x 336 divided by Tire Diameter
In your case it would read:
85 x 4.7 x 0.636 x 336 / 34.5 equals 2,475 rpm at 85mph
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
My Raptor with 4.10's, 10-speed, and 35" tires is turning 1800 rpm at 70mph. According to the calculator 4.70's, 10-speed, and 32" tires will turn 2197 rpm at 70mph.
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
just think of all the extra money for accessories having to slow down and no speeding tickets lol
20Bronco21
This is specific to the Bronco, where the axle ratios, overdrive ratios and tire diameters are known. You would need to check to see what your overdrive ratio is for your Raptor. I do not know if the 10 speed transmissions carry the same ratios across the board.
Silver-Bolt
Bill
10th gear in both applications is .636-1.
20Bronco21
lowmpg
Ryan
Maryland
F350
Likewise my F350 running 38x13.5x22s and 3.55 gears runs at 70-80mph all day with no issue.
