Sasquatch or Not Sasquatch+aftermarket ?
Sandbergo
Jelani & Dave
Orlando
Rogue
So I have yet to put in my order mainly because of a few issues. First, I have been trying to determine if I can justify going with the Sasquatch even though I’m not sold on the rims. I have been debating whether to just change the rear axle drive ratio and get the rear locking differential then go aftermarket for all the rest. The plus side of doing the Sasquatch is that it’s factory and will be covered by whatever warranty Ford offers. The second part of my issue is that I’m likely being allocated a 22MY since my reservation is from 7/26 so my issue is what paint colors are going to carry over to the 22MY, what packages, etc. Thanks Ford and Covid for throwing curveballs. Anyway, at the moment I have set up a Big Bend 2.7L 4 door Area 51 with MIC top, black interior, adding the Mid and Tow package, would go for the High if it was availble. I just think some of the other interiors are terrible, just my opinion. So if you have made it this far, what are your thoughts on going aftermarket for a non Factory Sasquatch package?
Firefly
SW Idaho
2003 Ford F250 Super Duty
https://www.bronco6g.com/forum/threads/ok-time-to-pull-the-trigger-squatch-or-no.12262/
saban
Alabama
Jeep
sas seems worth it if you are not getting a badlands.
if you get a badlands i would just skip sas.
then you could
  1. stay with the stock badlands wheels and 33s
  2. sell the stock wheels get better wheels than sas has ($2.5k savings + ~$600 from sold wheels to work with)
  3. sell stock wheels and stock tires ($2.5k savings + ~$600 wheels + ~$750 tires to work with)
So if you were to sell stock wheels and tires, you would be working with nearly $4k difference in price of sas but end up with better tires and wheels easily. Unless im missing something else that badlands sas adds
Corsair
Jacob
San Francisco
Escape
then you could
Its definitely more than wheels and tires.
saban
Alabama
Jeep
like what, the badlands model comes standard with 4.7 gearing and front and rear lockers. sas adds different tires and wheels and fatter fender flares to a badlands
Jackattack
Jarmon
LA
Bullsh
then you could
Badlands doesn't allow 4.7 final drive without sas. But I don't think the 5% reduction will negate the ability to run 35's. 37's yeah but thats getting into lift kits anyway!
Jackattack
Jarmon
LA
Bullsh
4.7 is only applicable to badlands through sas. Verified this when I made my order. Hope this helps!
BigFootie
Wisconsin
Not true, the MT7 comes with 4.7 on the Badlands
Corsair
Jacob
San Francisco
Escape
Badlands comes standard with 4.7 gearing with a manual transmission. Which is currently not able to be ordered with Sasquatch. There’s also a slight lift achieved with ambitious means. And and apparently a bump stop.
If you can swap your gearing and and get bigger tires for under $2,500, then go for it.
Edit: Also, the OP wants the 2.7, so that renders the talk of a manual irrelevant.
RiseAbove
Tom
Fort Mill SC
Dodge Challenger RT
then you could
Forgot about gearing and labor (if you can’t do it yourself), and added warranty for whatever that’s worth.
saban
Alabama
Jeep
i didn't read he had to have a 2.7.
haha so ford gives 4.7 gearing standard on badlands with the 4cyl. but if you upgrade to the v6 they take away 4.7 gearing.
DeltaBravo
Delta
MIKES MOM
I didn’t go sasquach. I went SAMSQUANCH!
RiseAbove
Tom
Fort Mill SC
Dodge Challenger RT
Yeah I’m still making sense of that.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
The rims are the least important thing about the squatch package.
Axles, gears, lockers, lift. That's stuff that cost real money to upgrade and stuff that makes a real difference. Wheels are a dime a dozen and can be had on the cheap and are basically just for looks.
Ii can't imagine basing my decision for squatch based on what the wheels look like, but I suppose if you are you probably don't need the extra performance anyway.
Jackattack
Jarmon
LA
Bullsh
Please correct me if I'm wrong. I'm sure I am as I'm speculating.
The gearing as far as tire size is concerned would be to increase torque to the wheels and remove stress from the drive shaft, transmission and motor, right? Maybe the auto and 2.7 can handle more torque. Might be why you cant match the 2.7 with the manual bc it doesn't allow for the stress of the 35's under full load. 🤷‍♂️ just speculating!
