webspoke
Stan
Pilot Point, TX
F450, GT350
Very informative without the standard youtuber fluff. Good showing the ranger/bronco differences. The wheel/tire weight is serious, and that is with a light 35" goodyear. A toyo or nitto will have you deep into the 90/100lb range. Thats nbd for big trucks, but is a lot of stress to engineer for on something mid sized. Its pretty cool to be able to buy a vehicle engineered and stress tested for that.
webspoke
Stan
Pilot Point, TX
F450, GT350
1) how much should a 35" tire and wheel weigh? (Good info for upgrading).
2)has anyone posted RTI scores yet?
Tire weights below - Ford did a good job spec'ing a really light tire.
Wrangler MT 315/70/17 is 52lbs
Nitto ridge grappler 315/70/17 is 70lbs, 35x12.5x17 is 75lbs
BFG KO2 315 is 62lbs, 35x12.5 is 66lbs
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
Overrated how? It does what its designed to do, and gives you extra articulation in situation where you need it. Add a lift and you add longer swaybar links. Nothing is going to "push you" to go manual...hell, you couldn't convince me to manually disconnect sway bars if I had the option
The SBD certainly works and is effective but I think itā€™s overrated on this forum. Iā€™ve had multiple Jeep Wrangler Rubiconā€˜s and I went on all kind of crazy trails connected and disconnected. I always made it no problem. The Bronco will be the same. Keep in mind, Iā€™m on the East Coast.
lakesinai
Charleston SC
Dan Edmunds has to be one of the most underrated channels on YouTube. Clear explanation of how everything works, even weighed the tire/wheel at 87.5lbs, (35s aren't light :)):
Hopefully we'll see this Bronco on his RTI ramp in the next video.
That was really cool to watch. I can't figure out how to message him, but I wish he would evaluate a regular Bronco without the Sasquatch like an OBX or a Big Bend so we can see the difference between standard suspensions and the Sasquatch suspension!
lakesinai
Charleston SC
With the wheel?
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
Glad he agrees with me on the non-sas Badlands 2-door being the best of the best.
Now if I could just get my hands on mine...
webspoke
Stan
Pilot Point, TX
F450, GT350
With the wheel?
That's just the tire weights. Now add a 30-35lb wheel, and then have to spin it up to 50-70mph. That's what kills the fuel mileage.
BrentC
Brent
Calgary, AB
Great video.
Interesting to see the stone guard on the rear shock remote reservoirs. I donā€™t recall seeing that on any of the pre-production Broncos.
Also interesting to see how thick the rotors are. Thatā€™s a good thing as modern lightweight rotors are prone to warping.
TXAG96
Tyler, Texas
'20 Bullitt, '01 Boxster, '87 TBird Turbo Coupe
I can attest to the weight of Squatch wheel and tire. Picked this up the other day. Switched out with spare and had it patched. I donā€™t plan on putting miles on that tire. Kinda sucks after only 3500 miles.
how the F did that happen????? Even the tape from the shank is still attached
rutherk1
Keith
Ohio
2021 Bronco Badlands 4 door Manual
I'm still trying to figure out the difference between the BL and SAS shocks/springs. I cant imagine they build a badlands non SAS and a badlands SAS with the exact same setup but one has springs that are 10MM taller.
PlayUltimate
CA
Toyota. 4Runner
understood on the 2 door... I wish he went into more detail on the 4dr... is SAS badlands on a 4 door the best? ..
goatman
Richard
Bakersfield
A bunch of Jeeps
Yep, pretty much the same, except what you said. Looking at the specs the BL SaS travel is slightly limited vs the regular Badlands, obviously because of tire clearance with the 35's vs 33's. The difference isn't much, though. To get the most travel without doing much with 35's, get the regular BL, add 1" spacer lift, and put 35's on it. You'd end up with about .5" more lift than a Squatch and the same travel as a regular Badlands. The only difference in the whole package, compared to a Squatch, would be the 4.46 rather than 4.7 diff gear ratio.
Oh, and great video. Good explanations.
BronchoPeat
Pete
Ohio
www.evergreenclothier.com
'18 Tiguan S w/4motion | '14 Fiesta SE Hatchback
I agree, I canā€™t find anything even close to that wrangler MT in terms of weight. Iā€™m sure there are lighter 17ā€ wheels out there that donā€™t sacrifice strength. I should take a look but Itā€™s a deep rabbit hole haha.
BdubBronco
Kentucky
2021 Bronco BD SQUATCH
Lucky I guessā€¦. I have a 7 minute commute to work, but there is a lot of construction in the area.
Something interesting is that at delivery, the tires were filled to 45 PSI though the suggested tire pressure is 39. I had let out some air to recommend pressure, but when I picked it back up, the local Ford Dealership had aired them all back to 45ā€¦.. Am I missing something???
Al Cowlings
Back of Beyond
Many
ā€œIt slots in halfway between a Wrangler and 4Runner.ā€
Sounds about right.
