Sasquatch tire downsize
Jacksonholio
2000 Tahoe Z71
Easy peasy or major issues if I want a tire closer to Badlands on my sasquatch wheels? I find the squatch tires a bit too wide and want the smaller flares like badlands. So I plan to keep all aspects of the squatch pkg just narrower tires on the same 8.5" wheels. Will it look odd or cause speedometer problems?
BTW this will be on my 2 dr Base Bronco on which I'll add the RTR rock rails.
ilbastarge
Northeast
Tesla X
Each size tire has a range of rum size that it can safely fit (defined by the tire mfg of course). Tiresize.com is a terrific resource for in depth information like that. Generally speaking of you put a tire on the wider end of the spectrum it will look wider but shorter and vice versa if you put it on the skinnier end.
SwerveBronco
Los Angeles
Chevy
I may be interested in taking your tires and wheels, as I did not order the Sasquatch on my Outer Banks and want the larger tires. I'm in LA, CA and my build is scheduled for January 10th.
Exomodo
Ryan
Marquette, MI
Ranger
Toyo and Nitto have a true 35 (or 295/75) on an 11.5 width, so you'd keep the speedo calibration on a narrower tire and a better tire compound than the Goodyear garbage... Anything narrower in a 35 and you get into weird Interco bias ply ag type stuff...
