Brakes - NO. The same. Sasquatch will take a loooooong time to stop on the road.
Top of the line Tacomas still come with rear drums. The brakes on the Bronco will be fine.
"Fine" is a subjective term. It means something different to everyone. What we should be asking is fine "compared to what"?Top of the line Tacomas still come with rear drums. The brakes on the Bronco will be fine.
Ok, what do you think will be the result of the following braking test?
60-0 mph
Stock Big Bend (32" tires & aluminum rims no options) vs same Big Bend w/Sasquatch (35" tires w/beadlock capable rims, heavier differentials, etc).
A) Stock Big Bend will come to rest in a substantially shorter distance than Squatched Big Bend
B) Sasquatch Big Bend will come to rest in shorter distance than stock Big Bend
C) Both vehicles will come to rest in about the same distance
Answer?
Not so sure."Fine" is a subjective term. It means something different to everyone. What we should be asking is fine "compared to what"?
Small tires (32") will break a LOT better than big tires (35"). Sasquatch breaking may be 'fine' for you, but please don't ignore physics. Those big tires will require significantly more breaking distance compared to Standard Bronco tires.
The following is the best video I've seen that compares 31", 33" & 35" tires in off-road and on-road conditions. EVERYONE SHOULD WATCH THIS VIDEO! Watch, then tell me what you think. They do brake comparisons towards the end.Not so sure.
I get it, the bigger wheels and tires are heavier but they also have a wider contact patch.
Modern brakes are very good generally speaking so I dont think you will see much difference with the 35s with braking.
This. Exactly. I'm off the pavement for the first mile and a half leaving and the last mile and a half coming home, in the mountains, subject to lake effect snow, blizzards, washouts of the road, etc. In my situation it makes sense to squatch it. If I lived where I used to, would not even consider squatching it. No reason to spend the $ for it. Does not mean that it is not still a bad ass vehicle...One thing I took from the Aussie video is that Sasquatch package is quite a value. But I’m not going to be off the pavement enough for it to be my personal choice.
Ok, don't get Sasquatch then. Enjoy your teeny little short braking tires...once the trucks are out there, you can sit in parking lots and go up and brag to Broncos with Sasquatch about how well you brake, and carry charts around to try to prove it to them. It's going to be awesome for you, stats and all."Fine" is a subjective term. It means something different to everyone. What we should be asking is fine "compared to what"?
"Looooong" is also a subjective term. It means something different to everyone. Ask my exwife."Fine" is a subjective term. It means something different to everyone. What we should be asking is fine "compared to what"?
