Sasquatch upgrades besides wheels? Brakes? Steering? Tie rods? CV joints?
colintrax
Georgia
Chevy Colorado, Ford Explorer, KTM 890 ADV
"Fine" is a subjective term. It means something different to everyone. What we should be asking is fine "compared to what"?
Small tires (32") will break a LOT better than big tires (35"). Sasquatch breaking may be 'fine' for you, but please don't ignore physics. Those big tires will require significantly more breaking distance compared to Standard Bronco tires.
They require more force to stop. I guaranafuckingtee the brakes on a base bronco will lock up the sas tires. You can't stop any faster than the tires have traction for.
Now will fading and warped rotors be a bigger issue for sas broncos. Yeah. But these ain't race cars, don't drive it like one and boiling brakes won't be an issue.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
You are dillusional. Sasquatch 35s will require greater braking than any other Bronco tire setup. This is physics. I'll gladly bet, if you care to put your money where your mouth is. So, I'll bet any Base, BB, BD OBX or BL stock will out brake any Squatch vehicle. Please bet me! I know I'm good for it.
I didn’t say it would. I said it could because there are more things that contribute to stopping distance than just tire diameter. One of the people mentioned the OBX which has harder tires and probably softer suspension. I’d be curious about that comparison because every performance driver knows sticky tires and stiff suspension decrease stopping distance.
I agree that with the same tire and suspension 35s will stop slower due to weight but it won’t be by much with modern anti-lock systems.
MVP
Orange County
From Esteban Plaza-Jennings ( Ford Brand Manager ) at SuperCel East while he and I stood by the model chassis- " There is no lift. Sasquatch has stiffer springs and longer shocks the BL. " Others from there quoted this and were told there is a small spacer used on the front.
Ok well that is confusing because he said no lift and then explained what a lift is. If it has longer shocks and springs then that is a suspension lift.
this is the big question that I have. If the springs are stiffer does that mean the ride isn’t as plush as a stock badlands? What is the true articulation difference.
if they don’t explain this before ordering I will just not get Sasquatch.
Boxer4
TRUCK
He looked at as starting out with different components, not a lift. Call it what you want. We are talking about 0.55" difference. 2 door Heights- WT-75.2 BL-73.8 = 1.4" . Tires WT-34.4 BL-32.7 = 1.7"/2 = .85.
ramblinwreck
Georgia
`22 Wildtrak, '21 Wrangler Rubicon 4xe
From that video he was using 305s as 33’s and 315s as 35s. Those are nearly the same tire. Most people consider 285s as 33s.
Anyhow considering the fact the 33 tire was a 34 and the 35 tire was a 34.5, I’d say that his breaking test was just heavily flawed.
at the speed he was going all he was really measuring was his reaction time, nothing more.
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
Might want to rethink that! Not that computer savvy, I think this the link to a very good and relevant tire comparison.
A day late and a dollar short. Has already been posted if you read the thread. Post #20.
SupremoSombrero
James
West Palm Beach, FL
2013 Mustang Shelby GT500
Bigger tires will have more rubber on the road. Modern brakes can lock up the tires at all reasonable speeds. Traction is the limiting factor for braking distances (my engineer WAG).
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
This went in a direction I wasn’t expecting.
squatch = stiffer springs = stiffer ride?
my original impression was the longer springs / shocks led to more travel and the position dampening shocks led to more control over any uneven surface (ie video of Broncos in Johnson valley hauling a$$ over broken ground at King of Hammers last year). Common reviews of Sasquatch versus standard Bronco (YouTube) is that the standard Bronco has better on road manners, but stiffer ride was never part of this description. I’m following this thread as well because my plans include Badlands or Squatch shock / spring take offs.
