Sasquatching my Non-Sasquatch Badlands
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
All that video showed is that Hell's Gate isn't as hard as it sounds.
It's a straight forward obstacle, but it requires attention and quick adjustment to several different factors, all while listening to the spotter. The vehicle needs to stay completely level, while balancing on the outside edges of the tires, or you risk sliding into the V. There are several places where one or more tires will lose traction so lockers or a smart LSD system is a must. The top of the obstacle is very steep and short wheelbase vehicles have gone ass over teakettle back down the obstacle before. I've never been up it but I've watch more experienced drivers than I fuck up their trucks attempting it.
FWIW, it was Dan Micks son driving that Sorrento, so it's about as close to "professional drivers on a closed course" as you get in Moab.
Marauder
Josh
St Louis
They took a more-or-less stock Kia Sorrento on Hell's Revenge - you should be good with the BL 33s.
Good to know my wife’s car can do that.
guess I should push harder for the Manual Transmission now that I have this as leverage
Apples
Nick
swooshdave
Portland, Oregon
Mustang
Does the Kia have either lockers or smart LSD?
At least they were honest and said they were going to disconnect the sway bars before attempting it.
Apples
Nick
I assume they have the same type of fake lsd/independent braking that a lot of vehicles, including the Bronco, are getting lately.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
I am in the same boat as @OJ_Loose , Badlands 7MT non-Squatch and bet I can self-manSquatch when the tires wear out.
My only debate is wheels. I like the BL optional wheels, but would have to take them off for a smaller offset set when self-mansquatching. So conflicted to order those or not.
OJ_Loose
OJ_Loose
Clay
Chester County PA
2019 Ford Ranger
That's exactly where I am at with it. Going to self ManSquatch it once the factory tires wear out. Just not sure on wheels... Glad I'm not alone on this
swooshdave
Portland, Oregon
Mustang
Is it fake if it works?
Desert_6G
Phoenix, AZ
Ranger
I want a 2-3" lift in my BL and that's it. The suspension is already good and you'll have be spending $$ if you want something better. I'm happy with tire and wheel size as stock. I dint need 35's for what I'll be doing. But we'll see how the mpg is first.
GoneAndDusted
PNW
I was going to get the optional wheels, but after debating it, didn't see the need in spending $1K on a set of rims that I'd most likely replace when going to 35s. I am debating getting the stock wheels powder coated a solid color until I decide to add a suspension lift and aftermarket wheels.
Apples
Nick
Fake in that it isn't a true limited slip differential. How well it performs doesn't really come into play.
akturbo
Seattle Eastside
'21 Bronco, 3500HD Chevy, Rav4Prime, Turbo Skidoo
I'm in the same situation, going back and forth to Sasquatch my Badlands. I removed Sas, however I wanted the 4.7 ratio, which automatically adds back the 315s which apparently adds back Sas even though this popup doesn't call it out. Signing order today, guess I'll go Sas since I don't want to mess with gearing later.
Ford Bronco Sasquatching my Non-Sasquatch Badlands 1614703624612
Ford Bronco Sasquatching my Non-Sasquatch Badlands 1614703851009
GoneAndDusted
PNW
I would pay less attention to build and price, and just follow what's listed in the Order Guide. For the Automatic on the Badlands, this note appears in the Order Guide under Axle Availability.
Ford Bronco Sasquatching my Non-Sasquatch Badlands Screen Shot 2021-03-02 at 8.56.14 AM
Ford Bronco Sasquatching my Non-Sasquatch Badlands Screen Shot 2021-03-02 at 8.56.29 AM
akturbo
Seattle Eastside
Thank you! Am I reading correctly that A3 code matches what I'm seeing in build and price? Sas required for 4.7?
