Massive Speed System Billet High Clearance Intrusion Beams - 2021 + Ford Bronco
First BILLET OPTION ON THE MARKET & MADE LOCALLY IN NORTH CHICAGO
Features
- Gain Tire Clearance Without Compromising Safety
- Additional Tire Clearance: 1.7" In Front and 1.2" In Rear
- Prevents Moisture And Debris From Gaining Access To Vehicle's Frame
- 6061 Billet Aluminum Construction
- High Strength Grade 10.9 Zinc And Yellow Plated Hardware Included
- Anodized Finish Available in 5 Colors
These crash bars are made from a solid brick of 6061 Aluminum through a highly accurate CNC program to ensure an easy, secure fit into the OEM Crash bar mounts. Note that hardware is INCLUDED! High quality 10.9 zinc plated hardware that will withstand the elements and heavy wheeling.
While gaining this much-needed clearance was crucial, we didn't want to sacrifice integrity, so Massive machined these ones from a solid block of 6061 Aluminum - lightweight and STRONG! They also won't rust like a steel one WILL. Their solid nature also impedes moisture and salt from gaining access to the inside of the vehicle's frame, unlike stock or other aftermarket versions.
The Massive Speed System Billet High Clearance Intrusion Beams for 21-Up Bronco are now available and shipping immediately. Contact your favorite Panda Motorworks Employee or head over to the Panda Motorworks Website
EXPIRES 12/21
